adjusting timing
Discussion in 'General Maverick/Comet' started by runeking40, Sep 9, 2010.
  1. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    I have my engine done and i was wondering how am i going to adjust the timing because the water pump that is revers rotation is covering up the timing marks on the crankshaft
  2. maverick75
    Can you install a pointer on the other side? (Like off a car that uses the reverse rotation pump) If so you can buy those timing mark decals that they sell. Find true TDC and attach the decal on the balancer to match up with the TDC line. Then set the timing.
  3. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    Why does rotation of the water pump have anything to do with covering up your timing marks?
    Now if you have a 302 water pump on a 289 timing cover and balancer or the other way around it will but other than that................
    it has everything to do with where the inlet for the water pump is.
    Is the inlet for the water pump on the drivers side or passenger side?
  4. runeking40
    runeking40 Member
    Illinois
    1973 maverick
    it is a drivers side inlet covering the timing marks
