AFR Heads
Discussion in 'Technical' started by C trout, Jul 21, 2013.
  1. C trout
    C trout Member
    South Carolina
    1977 ford maverick
    I've been looking into aluminum heads to get for my 302. Ive seen pretty good results out of them, does anyone here have any experience with them? For a stock 302 would it benefit more from 165 or 185's? And are they really worth ~$1500?
  2. Krazy Comet
    Stock???
    Unless you modify with a better cam, intake, carb, headers & exhaust, you won't see anywhere nearly the potential of the alu heads no matter who the mfgr is...
  3. maverick75
    Are they worth it? Absolutely
    Stock-mild build 165 are plenty. You have to build the whole package to support it though, intake,cam carb, etc...
  4. C trout
    C trout Member
    South Carolina
    1977 ford maverick
    Oops, Ive also got a performer rpm intake and a 650 edelbrock carb. But heads are what I'm looking at next, I plan to cam after the heads with something along the lines of an afm n-41 or similar. Reason I asked why the 185s may be an option I because I've heard they offer all of the numbers of the 165s but a little better top end power.
  5. scooper77515
    May as well swap out the cam if you have it all apart for a head swap.
    Cams are cheap, relatively, compared to AFR heads.
  6. Krazy Comet
    That N-41 is going to have some rumpty-rump, I wouldn't consider it unless you have approx a 2800-3000 stall and 3.50 gears...
    AFM N-41 - 222*/232* - 278*/286* - .512"/.512" - .320"/.320" - 110* - 106*/114*
    Overlap: 62 degrees.
    1.6 Rocker Ratio
    Intake Opening: 1* BTDC
    Intake Closing: 41* ABDC
    Exhaust Opening: 45* BBDC
    Exhaust Closing: 5* BTDC
  7. C trout
    C trout Member
    South Carolina
    1977 ford maverick
    Already have the gears, and may as well order a converter once I get the rest of the money for the heads/cam. My main concern with that cam is ptv clearance, but I've looked into it and it should work.
  8. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Every engine is different, always check ptv clearance. Also if ptv clearance is a concern, with tfs twisted wedge heads you can usually get away with up to .560 lift without issue.
  9. C trout
    C trout Member
    South Carolina
    1977 ford maverick
    Looked into those too, but they had mixed results, whereas the AFRs have had nothing but good as far as I've seen.
  10. Krazy Comet
    I love my Twisted Wedges, have run them since '99 on a zero deck(actually about .003 out of the holes)no valve relief, flat top piston 5.0... Just freshened, they are about to find their way on my new 331 short block... I used the Stage-1 TF cam with them, now have upgraded springs and will use same cam with 1.7 rockers...
  11. C trout
    C trout Member
    South Carolina
    1977 ford maverick
    Do you have any numbers for that setup? I'm looking for somewhere in the ballpark of 300-320 hp/tq.
  12. scooper77515
    Shoot for closer to 380 with those heads. I am running GT40 iron heads, and pushing 360-ish with a nice flat torque curve.
  13. junrai
    junrai Member
    rancho cordova ca
    you should be able to hit those numbers without afr heads. a good cam heavy springs a good intake and carb setup along with a good distributor setup should bring you close to where you want to be. as long as your lower end is in decent shape.
    I was told I should be producing 350 with my set up. I have a 302 .040 over an extreme energy comp cam kit (came with springs and lifters) headman headers a typhoon intake and edelbrock 4brl along with a hei distributor and 8mm wires and a double roller timing chain
  14. scooper77515
    Mine is 5.0 roller, .040 over, with decent cam, getting about 360. Specs in my signature.
    Fun little ride, 20 mpg if I keep my foot out of it. or 1 mpg if I stomp it.
  15. C trout
    C trout Member
    South Carolina
    1977 ford maverick
    380 to the wheels or flywheel?
