Aftermarket Headlights
Discussion in 'Cosmetic' started by Wolf Mcbee, Apr 26, 2015.
  1. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
  2. z28th1s
    Lynchburg, VA
    I just use the Sylvania halogen replacements in mine. I have been happy with them.
    Hotrock likes this.
  3. 71gold
    and $200 cheaper...:thumbs2:
  4. z28th1s
    Lynchburg, VA
    That is a big plus too!!
  5. Moneymaker 1
    Panama City Florida
    I tried some with the "diamond cut" reflectors, they were garbage, couldn't even see to drive at night.
  6. junrai
    junrai Member
    rancho cordova ca
    I picked up a set of tri bar headlight at a swap meet a few years ago but theyre NOT all that.
    luckily I paid $30 so not a big deal
    Ive never used those as I wont risk hundreds of dollars
  7. Rasit
    Rasit Member
    SE Pennsylvania
    Lots of cheaper options available. Search something like "Harley shovelhead headlight" or similar. Seven inch headlights are very common aftermarket..... As long as it's seven inch it will bolt in. Might have to modify the wire connector.
  8. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    yea thats my only concern is the wiring connector for it
  9. Rasit
    Rasit Member
    SE Pennsylvania
    Soldering gun and heat shrink and anything is possible
    Shorty and Krazy Comet like this.
  10. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    If your going cheap stick with the sylvania sealed halogens
    The ebay stuff is junk
    if you want to do an H4 conversion Daniel Stern lighting
    if you want a projector LED then JW Speaker
    If you want a true projector HID then
    Dapper Lighting
  11. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    With any factory or aftermarket you should install relays . It will increase voltage to light by almost 45% = bright light
    dgodding likes this.
  12. Krazy Comet
    I doubt it's anywhere near 45%(that'd be only 7.7v with alt charging 14v), still a couple volts increase is well worthwhile...
    When I put the headlamps back into my Comet I noticed one was brighter than the other(it has it has relay upgrade), so I took a look at each... Dimmer one is a std Sylvania halogen, the brighter is a Sylvania Performance which I assume is one of the Silverstars(I've not pulled it out to double check the number)...
    http://www.ebay.com/sch/i.html?_odkw=Sylvania performance h6024&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XSylvania silverstar h6024.TRS0&_nkw=Sylvania silverstar h6024&_sacat=0
  13. bmcdaniel
    I bought ebay tri-bar halogens 8 or 9 years ago, they're ok. Definitely better than the stock sealed beams. Did have to make the hole larger in the rear of the headlight buckets, though.
  14. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
  15. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
