air conditioning line question
Discussion in 'Technical' started by bomrat, Feb 22, 2015.
  1. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    hi, I need to make custom lines for my 74 comet. the expansion valve is:
    expansion valve - Part #94-9884
    Liquid Inlet #6 Liquid Inlet Thread 5/8" - 18
    Suction Outlet #10 Suction Outlet Thread 7/8" - 18
    what kind of fittings are these, are they male o ring?
    also on the drier and condenser there are 2 fittings I need to figure out.
    the top one out of the condenser is the larger of the two and is facing to the drivers side on top.
    the one on the drier top is facing towards the front of the vehicle, this is the smaller port.
    are these female o ring?
    thanks arlan.
  2. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    Hose ends are normally male o ring. Hard to find locally, most parts stores don't stock them anymore, or look at you like you have three heads when you ask about them. Try Vintage air for components.
