Air shock's
Discussion in 'Technical' started by elchinelo72, Oct 2, 2006.
  1. elchinelo72
    elchinelo72 Member
    Los Angeles
    71and 72 ford maverick's
    is it hard to install air shock's? on a 71 Mav-302.?:huh: Any sugestions :smash: guy's?
    Thank's:drive:
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Not hard at all. I did on my '71 in about 20 minutes.....It helps to have all the required tools on hand (nothing special,just your basic hand tools). Good luck,Hotrod-Daddy(Tim)(y)
  3. elchinelo72
    elchinelo72 Member
    Los Angeles
    :tiphat: Thank's Hotrod.
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Air Shocks are not recommended for Mavericks/Comets...
  5. stmanser
    Davenport, Iowa
    i have air shocks on my mav... you can air it all the way up for the fake rake in the back... but for the track i must say they are not that great.
    they will help to hide sagging leaf springs.. but thats about the only use for them in a mav
    i need reg shocks... just not sure which kind to get for my drag race application..
    anyone??
  6. scooper77515
    For only the 2nd time in my life (just exaggerating), I agree with TL...Air shocks were cool when I first bought my mav and wanted the a$$-end way up, but when you look at where they mount to, and where the pressure is put when you hit a bump or gun it, you will want to take them back off.
    They will eventually punch through the thin metal at the top mount and end up in your back seat-back...hopefully, your mother-in-law is not in the back seat when that happens (or hopefully so...naw, that is just plain mean :evilsmile )
    Go with the stock shocks. get lift from shackles if you really think you need it.
    But not too big if a shackle, maybe an inch max.
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The upper shock mount was never intended or designed to handle the weight and punishment of the car bouncing up and down on them ... that's what leaf springs are for ... listen to these guys. And if you have rust in this area your air shocks will punch through your trunk floor that much sooner ..
  8. newtoford
    newtoford Member
    New Castle Delaware
    yeah i'd just go with stock shocks and maybe an extra leaf on the new leaf springs
  9. bmcdaniel
    You can have a chassis shop rearch the leaves for about $30-$40. Even if that makes the rear too high you just use some lowering blocks to dial it in where you want it.
  10. bobmav
    bobmav New Member
    in utah
    dont have one yet soon i hope
    NO NO NO they came stock on a comet i know of
  11. Jamie Miles
    NO NO NO they did not.
  12. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I have broken the upper mount myself.
    Trust me, don't use air shocks.
    The weight that they will have to support is way more than what that thin metal will allow.
    If you look at the upper mount, you will see how flimsy it is.
    Tore the metal out of my floor pan. It was no thicker than the sheet metal on the rest of the car. Press on your fenders, then think about how the weight of the car will be focused on 2 or 3 square inches of that.
    Dave
  13. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    You are really over-thinking a very simple car. Get a simple pair of Lakewood 50-50 shocks for the rear of your car. If you insist that it's a "race car" then, by all means, slap on a set of 90/10's in the front. Otherwise.....put a set of 70/30 Lakewoods on the front.
  14. elchinelo72
    elchinelo72 Member
    Los Angeles
    well;thank's guys for all your advice I apreciated.
    I did not install them.got my money back:bananaman went and buy some cold ones:drink: and relax for the week end.:wave:
