Alignment troubles!
Discussion in 'Technical' started by Grabber71, Jul 31, 2009.
  1. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I am having some trouble with my recent upgrades...and am really hoping that someone might have some advice as to what may be the problem! I just did a disc brake swap on my '71 using granada parts...I decided to replace a few things while I was there. I replaced the springs..they were supposed to be the same as my original 250 springs but are about an inch lower...odd. Replaced the upper ball joints and the lowers. The tie rods were good so I left them. I took the car to two alignment centres but still can't get the car to handle nearly as well as it used to before the swap(but it sure stops good). The steering does not return to centre very well and it kinda feels sloppy..kinda like it is skating or numb feeling while going straight...but yet feels good when I turn. Has a bit of bumpsteer. One of my strut rods is almost bottomed out(end of threads)...which is really odd! The car is within alignment specs..but is really disppointing me as this point! Neither shop know what is wrong with it but both feel it is not good! I am supposed to be racing in the Kent "Pinks all out" race coming up in a few weeks...but am unsure about how this thing will feel at 120mph! Don't want to make the T.V by hitting the wall! Any ideas or thoughts are very much appreciated....
  2. mean_maverick
    if u replaced that much, i would have went ahead and put new inner and outer tie rods on it. that way, it would have eliminated almost any guesswork in the steering. just my thoughts...
  3. blugene
    Check for worn parts, maybe rag joint? Worn gear box? Can you scan your alignment sheet and post it?
  4. 510madmav
    510madmav Member
    San Francisco bay area
    1973 Maverick
    the new springs you put in may have set your camber negative.
  5. blugene
    That and or they don't hold up when going down the road and come in (negative) causing issues. Something is up if the rod(s) are at the end of the threads too. Hopefuly not tower flex.
  6. Mavman72
    The strut rods are used to adjust the castor on these cars and it sounds like the castor is off...Hence the skating feeling in the front end,and the lack of thread on the strut rods..It took me 3 tries to find someone who knows how to "properly" set up our front ends.Perhaps the tech just didnt know how to do it.Most new cars only have Toe settings...The rest isnt even adjustable.
  7. sierra grabber
    sierra grabber Certifiable
    northern nevada
    make sure the upper a arm bushings are not worn, but i doubt that changed too much. Did you replace the bearings or use the ones from the granada? also make sure the alignment tech got the camber bolts tightened back down right. i had one leave that loose and when i hit a bump the steering wheel changed by 90 degrees while i continued straight (talk about scary):49:
  8. blugene
    You do realize your on the Mav forum and not the F trucks forums? :D
    Sorry, I have never seen a drag link that adjusted caster.
  9. rthomas771
    I think he ment to say strut rods. The drag link is the same thing as center link
  10. Bryant
    it doesnt have enough caster. this problem occurs when you lower the car. this removes caster so the strut rod have to be pulled forward to adjust for it. the better thing to do is to put a shim in the upper control arms font bolt. this will give you the caster to get the the handeling in order.
  11. Mavman72
    What rthomas said...Sorry blue...sheesh I'm tired.
  12. gearhead1966
    gearhead1966 New Member
    washington ill
    1970 ford maverick x prostock
    the steering not returning to center is usually caster...need more positive...but could also be from the spindal change? do you know if they both have the same steering axis inclination? i would look at the alinment specs of the maverick and compare them to the granada you took the spindals off of. i would need to see specs. hell most people in those shops dont know what the hell they r doing anyways. should be 0 -1/2 neg camber and 2.0 - 3.0 pos caster with about 1/8 toe in i would also make sure your upper control arm pivots r in good shape as that will make a car dart side to side if loose
  13. Grabber71
    After 3 try's at an alignment shop I brought the car over to my Dads place for him to have a peek(back yard Mechanic). He found the problem in less than 5 min! The strut bars were loose(over 1in on movement going from forward to reverse! The rubbers were toast from all the slop and the steel bushings were trashed! I have no idea why the shop never even bothered to look for problems when they were obviously have trouble getting everything in spec! 4th alighnment at a differnent shop and everything is perfect...awesome!
  14. Mavaholic
    I was going to suggest a different shop. About 20 years ago I had the same problem after rebuilding the front of mine and converting to disc. Took it to get aligned and it handled like crap. Steering would not recenter itself was just one of the problems. After repeated trips to the same shop I finally gave up on them. His last excuse was all the new parts made the the steering so stiff it wouldn't return. I said when it was new it had all new parts and I didn't have this problem. After a few choice words, I took it somewhere else. The guy was an older guy who knew what he was doing and aligned it correctly. No problems since. In your case, if the first guy didn't see that strut problem, I'd go else where.
  15. darren
    Glad to hear its all good. Its hard to find guys to fix these old things properly. Our front end mans an old fart so he knows his stuff. Donig my car this week. It drives great so I dont think he'll change much.
