alluminum drifeshaft
Discussion in 'General Maverick/Comet' started by RSH MAVERICK, Jan 21, 2011.
  1. RSH MAVERICK
    RSH MAVERICK Member
    Augusta GA
    71 maverick grabber
    does anyone have a alluminum driveshaft if so what kind and size ? .. is there one that will interchange with a maverick ?
  2. injectedmav
    injectedmav Member
    Georgia
    I have a 3.5" that I am about to have shortened to install. I don't know of any that directly fit without modification
  3. Fro
    Fro Member
    Joplin Mo.
    19691/2 maverick 1971 maverick
    I've ran a ford racing aluminum driveshaft from a fox body mustang for years now, you just need to change out the rear u-joint.
  4. Recrdholdr
    Recrdholdr National Record Holder
    London Ontario
    I want a 70-73 Maverick
    Most Mid 90's and up Mustangs have Aluminum driveshafts, I doubt they will bolt right up but it may be a good place to start.
  5. 71gold
    I will sell you this one...:thumbs2:
  6. 71gold
    OH, I should tell you...it looks like this now...:yup:
    ...:outtahere::chirp:
  7. starsky74
    starsky74 Technician
    Hackberry Louisiana
    actually, they do with the correct swap u joints
  8. Fro
    Fro Member
    Joplin Mo.
    Not mid 90's, fox body Ford racing aluminum fits right in after a U joint swap, I ran the OEM steel version before the aluminum shaft, the 95-98 drive shafts are too long for the mavs- comets.
  9. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Yes the member here named "Shinysideup" has a Ford racing aluminum one in his Maverick that is for Fox mustang and he said it bolted right in.
    http://mmb.maverick.to/showthread.php?t=42391&highlight=driveshaft
  10. darren
    That looks just like the one in my Mav. I had to get a different joint for mine. The Mav joint was too narrow to fit the driveshaft. The u joint cross is 2 different widths as mentioned to fit this shaft to the 8".
  11. mercgt73
    mercgt73 Member
  12. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    The correct U joint is precision part # 347
  13. Clintd
    Clintd Member
    Parlin NJ
    never mind, 347 is not the right joint. it has the correct end for the rear just the wrong caps for the drive shaft. found out after driving one of the caps ino my mustang driveshaft and stretching the eyelet out. also the clips are different.
    I cant believe that out of everybody that has done this swap not a single one wrote down the part #
  14. mercgt73
    mercgt73 Member
  15. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
