Alright, whats going on here!
Discussion in 'Other Automotive Tech & Talk' started by justin has a 74, Sep 17, 2010.
  1. justin has a 74
    kentucky
    89 mustang 2.3 auto
    cut the exhaust off and changed an air filter, about 250-350 thousand miles.
    Driving down the road and the temp is surging from 170 to 240 for about an hour. Slightly after that it stays around 240 and begins to raise little by little. Electric fan (with Shrowed) and heater was on (trying to make it home by lowering the heat)
    Thermostat would be my guess.:hmmm:
    more info. Seems to overheat over 30 mph and under 70 mph,
  2. Jamie Miles
    That's all the rest of us can do, as well. Put the exhaust back on that 4 cyl, and do some basic trouble shooting..
  3. maverick maniac
    maverick maniac Banned
    owensboro ky
    small motors need a certain amount of back pressure ,,
  4. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Low coolant or not enough antifreeze, those are my guesses.
  5. Streetdeacon
    Streetdeacon Streetdeacon
    Bellingham, WA
    1977 Maverick 2dr.
    It could be the thermostat malfunktioning. I would check it first and then maybe the temp sending unit.
  6. rthomas771
    If it got that hot you would had smelled, heard and felt something. If it drove fine...then the gauge is telling a lie.
  7. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    How many can you park up by the chevy,,,
  8. 302-72-mav
    302-72-mav Member
    sactown CA
    i bet when he gets rid of that chevy the fords will run good // see what it is that chevy keeps telling the ford to get into trouble :naughty:
    yah sounds like the thermostat or a air bubble in the system
    if its the gauge get one of thoes lil metal thermometers and put it in the coolant when it gets really hot
  9. JHodges
    JHodges thumper
    Dora Alabama
    air bubble in the coling system would be my guess also, 2nd would be thermostat. Just make sure its full of coolant.
  10. justin has a 74
    kentucky
    ok thanks guys. Im going to try to find out where the heck this temperature gauge leads to and install my after market one. Car was running great.
  11. Dave B
    Why did you cut the exhaust off?
  12. justin has a 74
    kentucky
    I wanted to sound like a ricer!
    People i have talked to say that it runs alot better with 1 converter than 2 lol, im putting a glasspack on it. Hopefully it lowers the tone a little bit. Just wanted to do something different.
  13. jeolman1
    jeolman1 Member
    what kind of fuel system does it have? carb or efi and if efi is it open or closed loop? (with or without an O2 sensor)
  14. justin has a 74
    kentucky
    efi with 02 sensor
  15. mean_maverick
    please try to start thinking stuff thru before acting upon it..... :rolleyes:
