alt problems
Discussion in 'Technical' started by HOMERMAV, Feb 8, 2010.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    the alt light comes on and stays on while the car is running and i dont think its charging it has a new alt. and voltage regulator.is it wired right here is a couple of pics
    HELP
    thanks
    john
  2. maverick75
    Do you have a volt meter on the car?
    Also you might want to fasten this down:)
  3. maverick75
    Just found a pic of my old alternator, hope this helps you out(y)
  4. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    do you think its some sort of ground?
  5. maverick75
    I'm thinking its just to hold it in place:hmmm: i didn't find it in the wiring diagram
  6. rthomas771
    Alternator and regulator both need a ground to work. Wiring diagram shows a ground.
  7. Carl's Comet
    Carl's Comet Member
    East Brunswick, New Jersey
    1973 Comet
    Check your battery ground cable from battery to engine block, there should be a crimped eye a few inches after the top battery terminal that gets bolted to the lower voltage regulator bolt for chassis ground. If not the battery light will come on and the charging system will not work.
  8. blugene
    Might want to check the battery wire on the alt. It looks like it is on the wrong terminal. It's the black and orange thick wire. I bet it goes on the terminal with the red on the alt.
  9. apotter80
    apotter80 Member
    charlotte, MI
    1971 maverick grabber(CLONE)
    my car didn't charge right after got it. turns out it was a broken wire going to the voltage regulator on the fender well. stroke of luck i even found it. Man it ticked me off, and when i finally figured it out i felt like a dummy. might want to check out yours if your still having trouble.
