Alternator and PS Pump Spacers
Discussion in 'General Maverick/Comet' started by palser64, Mar 7, 2016.
  1. palser64
    palser64 Member
    Barboursville, WV
    1977 maverick , 1973 maverick, 1973 maverick, 1971 maverick grabber, 71 comet, 74 comet
    Could anyone tell me the length of the aluminum spacers on the bolts holding the alternator and the power steering pump on? This is a non-AC car. 1973 model with a 302 engine. Thanks anyone for your help.
  2. dyent
    dyent Member
    vancouver bc
    I think the spacer behind the alternator is 1 5/8" (8A652) and behind P/S pump bracket is 1/2" (3D600), do you recall if you had an aluminum bracket (D1OE-10A336-AB) mounted on RH (Passenger side) head??
    Melvin's has both spacers:
    B13195 P/S Bracket Spacer pg. 63 for $6.50
    D0OE-10A370-B Alternator Spacer pg. 42 for $11.25
    David
    palser64 likes this.
  3. palser64
    palser64 Member
    Barboursville, WV
  4. palser64
    palser64 Member
    Barboursville, WV
    I do have the aluminum bracket mounted on the head for the alternator bolt. I also have an assortment of aluminum spacers collected over the years. I can cut one to size if needed, however, I just wanted to see what size the original spacers were. Thank you for the information David. I really appreciate it.
  5. dyent
    dyent Member
    vancouver bc
    Hey, no problem and glad to help, just have to make sure you get correct lengths for your pulleys to all line up.
    Good luck!
    David
  6. Krazy Comet
    I dunno if there is a difference in '72 & '73 but thickness of my A/C bracket is ¾" where P/S sets... I also measured my spacer(a stack of washers) and came up with ¾"... One of these days I'm going to reinstall the A/C...
