Alternator/Charging help!!
Discussion in 'Technical' started by EldoNardo, Dec 27, 2009.
  1. EldoNardo
    EldoNardo New Member
    Whitinsville, MA
    1976 Maverick 6 cyl, and my daughter
    Hey all,
    My 76 Maverick started dying, thought it was the battery, replaced it - no luck.
    Had alternator tested at local Advanced Auto - they said it was ok, so threw in a Voltage regulator - no luck.
    Tried new solenoid - no luck.
    Current symptoms - alternator light still on with all the new parts - and doesn't seem to be charging battery. If motor is revved up to high RPM's, alternator light goes out... can't be sure if battery getting charge or not, it DOES seem to be holding at approx. 12.30 volts. Is this correct for functioning alternator/charging system?
    Is there a "reset" for alternator light?
    Driving me buggy, any help appreciated. Replies off list to - vmsmith45@yahoo.com
    Thanks,
    Mark
  2. rthomas771
    I went through 3 different regulators before I found one that charged at low rpm. I got the 3rd regulator at Napa
  3. EldoNardo
    Whitinsville, MA
    Thanks
    Will keep fingers crossed to find the original one and see if that functions.....appreciate the response.
    Mark
  4. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    Check the wiring for a ground or something. Specifically the one going to the light on the dash. Lime green striped.
    I gave up and installed a Chevy alternator and have never looked back.
