alternator not charging battery
Discussion in 'New Members Forum' started by devrin010, Jan 12, 2014.
  1. devrin010
    devrin010 Member
    dixon
    73 maverick
    I have a new battery alternator and voltage regulator but no charge I don't know what to do please help
  2. 71gold
    :Welcome:...:Handshake
  3. mojo
    Are we talking new or rebuilt alternator? You cud have a defective part. Have u sused a voltmeter and tested the output at the battery?
  4. mav1970
  5. Krazy Comet
    I'd look for wiring issues often problems in old wiring at plugs, terminals etc...
    If the fuse link mentioned was bad, vehicle would be totally dead...
  6. rthomas771
    I seen where some electronic regulators won't get excited until the engine is rev up to 2500-3000 rpm. After that...they will charge all day long until you shut off the engine.
  7. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  8. mercgt73
    mercgt73 Member
    The black/orange alternator charging wire is a fusible link. The yellow ignition wire is also a fusible link.
  9. MSmithPDX
    MSmithPDX Member
    Portland, OR
    You can also not charge if you have a bad ignition switch. The car will start and when it returns to run the switch fails, the car continues to run but the circuit for the charge system is broken.
  10. Krazy Comet
    True, thanks for straightening me out...
    Yes there is a fuse link connecting the alt to battery, if open battery will not receive charge...
  11. devrin010
    devrin010 Member
    dixon
    73 maverick
    black and orange alternator wire
    how many amps in the black and orange alternator wire
  12. mercgt73
    mercgt73 Member
  13. devrin010
    devrin010 Member
    dixon
    73 maverick
    How do i test the voltage regulator?
  14. devrin010
    devrin010 Member
    dixon
    73 maverick
    how do you test the switch?
  15. Krazy Comet
    I wouldn't even attempt to check the voltage regulator(and I've been working on this stuff almost 50 years), if it's old just replace it...
    As far as the switch, it's possible but if the car starts and runs OK otherwise chances are slim it's bad... You'd need a wiring diagram and then check with a ohm meter to be sure terminals are making contact in the various positions, almost as complicated as checking the regulator...
    Did you check the fuse link as suggested??? It's the most likely cause by a wide margin...
