Alternator Pegged
Discussion in 'Technical' started by MarulMav, Jan 9, 2007.
  1. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    The gasket maker worked on the water pump bolt. Another question; if all wiring is correct on my alternator, why would the amp gauge be pegged to its max reading; it does get pretty warm during a short start up.:yikes:
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    AMP guages are fires waiting to happen. Switch it to a volt meter and don't send all your alternator's output through the amp gauge.
  3. PaulS
    If it pegs like that you have it wired wrong. The ammeter is connected from the alternator to the main accessory supply line - it should never see your starter amps.
