alternator questions
Discussion in 'Technical' started by mcshank, Feb 25, 2012.
  1. mcshank
    mcshank New Member
    seattle
    76 ford maverick
    hey,
    I have a 76 inline 250 and just need to know what the stock alternator voltage is as well if anyone knows what size the rear end is, Just got my maverick back after my dad borrowing it for three years and he thrashed it so I am trying to get it back to solid, any help with this stuff would be awesome thanks
  2. captainmack
    captainmack Quad Door
    Alternator voltage??? it outputs 12 Volts DC.... Rear end is 8" 5 lug. The rear gear in the rear end can be read on a little metal tag on the rear axle center section. The identification plate on the car can be decoded to tell you all of this info!!!
    http://home.comcast.net/~petebre/maverick/decode/index.html
    I hope this helps you!
  3. rayzorsharp
    With the car running the voltage should show somewhere around 14.0-14.5 volts.
  4. mcshank
    mcshank New Member
    seattle
    76 ford maverick
    no what I am referring to is if I wanna replace the voltage regulator and they ask what alternator do I have a 61 amp or whatever. My car is all stock so I was wondering what it is?
  5. rayzorsharp
    Just tell them the highest amp they offer. Lot of them came with very low amp alternators such as 37 or 45 but the higher the better. Your car will handle it.
  6. mcshank
    mcshank New Member
    seattle
    76 ford maverick
    thanks for the info
