Alternator Wiring...Pic inside
Discussion in 'Technical' started by stmanser, Aug 14, 2005.
  1. stmanser
    Davenport, Iowa
    ok...the prob is..
    this alternator is from my 90 ford tempo that was totalled.. i knew that the wireing could be a prob...but andy said he got a 91 tempo alt to work...but his has an internal voltage regulator and internal fan..
    mine is external V/R..it is attached on the outside of the alt...etc.... the wires is the main thing....
    tell me exactly where the wires should connect on my maverick wiring...and i will be golden....
    thanks
  2. stmanser
    Davenport, Iowa
    i give up.......i cant understand why this site does not like me when it comes to putting pics up
  3. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Check your PM's. I think i figured it out
  4. maverick75
    hey stmanser or Andysutt can u post the PM because i would like to see it because i have a spare tempo
    thanks(y)
  5. Andysutt
    Conway Arkansas
    1972 Comet GT
    If its an internal regulated alternator email me and i'll send you the diagram
  6. maverick75
    yes it is and u have mail
    and i realized i am a dumba$$:mad:
    yesterday we had a thunderstorm come in and i frogot to roll up the windows on the mav and the tempo now the interior is all wet:mad:
    thats one thing i hate about southern california one day its hot as Hell and the next minute its pouring rain:mad:
  7. Andysutt
    Conway Arkansas
    1972 Comet GT
    You have mail also
    And sounds like your weather is like Arkansas's
  8. jim4rd
    jim4rd Member
    guess I wimped out when the alt died on the COMET , I got a ole style 3 wire delco , converted it , an now shes charges 14.0 volts all day long even at idle , just had to modify the adj. bracket a bit
  9. scooper77515
    Andysutt is busy sending e-mails.
    He is a benefit to all us Mav Forumers. :clap:
  10. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I would have guessed that a Tempo alt. would be totally different
    from a Mav/Comet alt. Why use it?
  11. Andysutt
    Conway Arkansas
    1972 Comet GT
    The tempo alternator is still a vbelt setup (so dont have to put on vbelt pulley, or convert to serpentine), internally regulated, internal fan...
    Clean look, and if you get one for an A/C car its 105 amps.
    Simple wiring. Its not technically a 1 wire setup... it had 4 wires going to it from the factory, but very simple to convert. Run one battery wire, a switched source, and then you jump 2 studs on the back of it. Very clean setup, I like it and if I can find the picture of it installed on my FE, I'll show you
  12. maverick75
    thanks andy for the diagram-now i have a backup if the mav's goes out
    heres the diagram for anyone interested
  13. Andysutt
    Conway Arkansas
    1972 Comet GT
    Sorry about not updating that diagram. I posted it on a ford truck website few years back and just never updated it.
    Works well, havent had a single problem out of it
  14. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    What gage wires are recommended for each color wire?
    Thx for the info.
  15. Andysutt
    Conway Arkansas
    1972 Comet GT
    Red - regular battery cable that you hook to alternator on any other car
    Blue - I used I think 12 gauge
    Green - same as above
    Yellow - same as above.
    Blue/Green/Yellow just use whatever you'd wire up a radio/electric fan, etc with.
    Doesnt have to be very big at all
