Aluminum Driveshaft
Discussion in 'Technical' started by 1moregear, Jan 20, 2009.
  1. 1moregear
    1moregear Member
    mississippi
    74 and 76 maverick
    Hey Guys I have been told aluminum driveshafts free up a little HP plus make for a really smooth ride . Is anybody running one? Also is anybody running a 325 gear with an automatic and how do they like it?:bananaman
  2. Bryant
    ive ran a alum drive shaft in my old fox mustang. it made a noticeable difference on the freeway for acceleration. i will probly put one in the mav sometime down the road. apparently the ones for the fox mustangs fit in the mav if you change the yoke. ive ran all kinds of different ratios in my mav. ive ran 3.25s with a 28" tall tires and thats a great all around ratio. you can go freeway speeds and keep it below 3000 rpm and still gets up and goes pretty well from a stop.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I've never ran one in a Maverick, however I have owned cars that had the aluminum shaft as stock equipment. They worked like a driveshaft should.;)
