Aluminum Radiator and Fan Shroud
Discussion in 'Technical' started by dmhines, Apr 24, 2003.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Does anyone sell an Aluminum Radiator that will fit a Maverick and also have holes to mount the stock fan shroud?? Thanks - Dan
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    The radiator I bought did not have connections for a fan shroud, hell it didn't even fit, atleast not until I got the sawsall out! :D :eek: :p
  3. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    i believe mavaholic's aluminum radiator was supposed to be a stock replacement size radiator.
  4. 1/4Mile Comet
    1/4Mile Comet Member
    Salina,KS
    I think you can get one that will bolt right in with fan shroud holes and all from Griffin but they are pricey like $500.00.
  5. Mavaholic
    Griffin does make a direct replacement radiator. Price was $552 thru Summit last year. Part# is GRI-7-570BU-FXX. It is a 2 row 1 1/2" tubes and has the flange to mount a fan shroud. Most of the universal ones are only 1 1/4" tubes.
  6. Maverick Man
    California
    becareful on some of those radiators "stock replacements" from girffin because some don't come with tranny line provisions. so you will need to run a external tranny cooler, which you should anyways. just fyi
  7. fordman
    fordman Member
    lufkin texas
    1972 maverick
    this is a be-cool 1970 mustang 460 radiator had to use the sawsall on it then it droped in the hole
  8. John B
    John B Member
    Ontario, Canada
    '73 Mav
    Fordman; Any chance of a picture that shows that rad cradle off a bit more? Thanks. John B.
  9. Ryan
    Ryan Ford Addict
    Phoenix Az.
    I was going ot ask a radiator question just like this today, guess I don't have to. That Griffin one sounds a little expensive. Since he is local here in Phoenix I will go see what he will sell me one for.
  10. fordman
    fordman Member
    lufkin texas
    1972 maverick
    this is the top
  11. fordman
    fordman Member
    lufkin texas
    1972 maverick
    bottom bend frame over to set rad in trim to fit
  12. fordman
    fordman Member
    lufkin texas
    1972 maverick
    trim the frame for bottom hose
  13. fordman
    fordman Member
    lufkin texas
    1972 maverick
    JOHN I BEAT THE TEXAS HEAT WITH THIS RAD HAD A STOCK THREE CORE( AIR CAR) THAT YOU CAN BUY NEW AT AUTO-ZONE IT WORKED FINE THE COOL DOWN TIME IS FAST WITH ALUMINUM
  14. Maverick Man
    California
    this rad won't fit without cutting the whole front brace off right? ... looks like you don't have one... what does the whole compartment look like?
  15. fordman
    fordman Member
    lufkin texas
    1972 maverick
    got to cut it
