Am I assuming right?
Discussion in 'Technical' started by maxsideburn, Mar 17, 2004.
  1. maxsideburn
    maxsideburn Member
    Lafayette, Louisiana
    1976 Ford Maverick (200CID I6/AUTO)
    I'm assuming that in order to move down one notch. Just jack up the car and then move it right? Just making sure I'm not biting off more than I can chew ;)
  2. maxsideburn
    maxsideburn Member
    here's the picture
  3. madmav74
    madmav74 Member
    north dakota
    74'maverick strip car
    heres the steps
    1) jack up the rear of the car under the dfferential as high as you can , place some stands under the body, I suggest putting them on the sub frames right in front of BOTH rear springs.
    2) lower the rear end just so the suspension is relaxed, remove shackle bolts.
    3) replace shackle bolts in lower holes and tighten(you may have to lower the rearend some.
    hope this helps.
  4. Mavaholic
    Why do you want to jack the car up further? Its not safe. It puts more strain on the front end components. It makes the car handle even worse than they already do. Reduces rear wheel traction. Shall I go on?
  5. John A Fasig
    John A Fasig Member
    over here now
    several plastic and tin
    It's not safe
    Is that a big rust hole under there? SAFTEY FIRST.
    IT'S ALL FUN AND GAMES ---- TILL SOMEONE GETS HURT.
    Let's all have a SAFE and fun summer. John
  6. Craig Selvey
    I will get to the point. Those things are a death trap. Death to you...and death to the car. You jack that thing up anymore and the amount of stress and torque put on your rear frame rails will rip that car about. Bottom line....remove those things.
  7. 71gold
    no no no no nooooooo!!:eek: :eek: :eek:
  8. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    New 4 leaf springs and stock shackles will accomplish the same thing but be alot safer and a nicer ride.
  9. John A Fasig
    John A Fasig Member
    over here now
    jUST REARCH THE OLD ONES AND ADD A NEW ONE
  10. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    I've got to through in with the rest of 'em. Lose those shackles!!! The suspension on go-cart is safer.
    :smash:
  11. dmhines
    Cumming, GA
    Go-Kart?
  12. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    No if that is not a car guy in the making, I've never seen one. That is a handsome kid in a spiffy car.
    (y)
  13. dmhines
    Cumming, GA
    Where is Rex, Georgia? I am in Cumming.
  14. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    The big city of Rex, Ga is down around the Morrow, Ellenwood, Stockbridge area. I am about 5 miles form I-675. :)
  15. Charlie
    Charlie maverick.to/grabber
    Indianapolis, IN
    1970 Ford Maverick Grabber (Modified)
    Its obvious from the picture the bushing is completely shot.
    Get new shackles and bushings. :)
