Another header thread.
Discussion in 'General Maverick/Comet' started by maverick600, Dec 10, 2019.
  1. maverick600
    maverick600 Member
    San Angelo, Texas
  2. mojo
    I wouldn't take a chance on those fitting the Maverick! What if they don't work, are u willing to modify or lose the money invested. I would rather spend another hundred and get new headers, know to fit and be done with it.
  3. Krazy Comet
    Without mods, ZERO chance any header for a Fox chassis is going to fit.
    TeeEl likes this.
  4. ike72com
    ike72com Member
    Charleston SC
    I just installed headers that i had on my 1970 mustang. They were hedmans long tube. Fitted like it was made for car. I looked at the numbers before i painted but did not write it down. Will try to verify numbers tommorrow.
    You got Stock exhaust on car now i assume.
    BBMS18 likes this.
  5. maverick600
    maverick600 Member
    San Angelo, Texas
    I'm preparing for a future v8 swap
  6. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I’ve come to ta realization that there’s no sure answer for what headers fit, because I’ve heard of people modifying 6 cylinder frame mounts when doing V8 swaps along with installing transmissions that never came stock in Mavericks/Comets like AOD’s, T5’s etc which require custom or modified crossmembers.
    I feel these details are not communicated well when stating header “A” fits or doesn’t fit.
  7. ike72com
    ike72com Member
    Charleston SC
    Headers have always been a pain in the butt for me to install. Very tedious work.
    A lot of first time installers probally either try to drop in from top or push up from bottom.
    I've always had to undo motor mounts and lift engine. Then wiggled in place and lower motor.
    If application is wrong you'll find out.
  8. mojo
    I installed Hedman shorties last year, didn’t lift engine. Only needed swing idle arm away from frame and passenger side slipped right in from bottom. Drive side went in even easier.
    ike72com likes this.
  9. ike72com
    ike72com Member
    Charleston SC
    Mojo!!! Thats great news for guys who want shorties.
    Long tuber guys might not get so lucky
  10. maverick600
    maverick600 Member
    San Angelo, Texas
    I'm thinking that shorties are the better way to go with these vehicles. That's what made me wonder if the mustang headers would work.
  11. Krazy Comet
    I tried a set for fit when I swapped the 5.0 in my Comet, no chance.
  12. mojo
    Main reasons I went shorty! One man/me installation and 70+ years of age -- want less install issues as possible.
    The only thing needed after install is the collector will hit pitman arm on hard left turn; it won't present a problem normal driving. I will/intend to take back to muffler shop and have collector dented or modified. I don't have any regrets w'/ my choice. I will state, the long tubers didn't have an issue w/ pit arm. If I had a race car, would have went back to long tubes.
  13. maverick600
    maverick600 Member
    San Angelo, Texas
    Do you have manual or power steering? That seems to be the difference with the pitman arm.
  14. mojo
    I have power steering. Pit arms are different and that may have some bearing on contact w/ collector. Maybe someone w/ manual can add something too this conversion.
  15. maverick600
    maverick600 Member
    San Angelo, Texas
    I would agree, from what I have read during research, power steering seems to be the culprit. As you said, hopefully some with more knowledge will chime in.
