Another squeky front end
Discussion in 'General Maverick/Comet' started by sanders739, Dec 29, 2011.
  1. sanders739
    sanders739 Member
    Washington St.
    72 4dr, 70 2dr, 75 4dr
    So i just replaced my spring perches with roller perches and also replaced the upper ball joints with grease less ones and the control arm bushings. The front is driving me crazy, i can hardly bare to drive it it squeaks so bad. Any suggestions would be much appreciated.
  2. mercgt73
    You lubed / replaced the upper control arm bushings? Sway bar bushings / end links? Did you replace both upper and lower control arm bushings? What about lower ball joints?
  3. CommieHook
    CommieHook Member
    Hot Springs, AR
    1974 Ford Maverick 4-door
    Oh buddy, I feel your pain... I had the upper ball joints and lower control arms/ball joints replaced, and boy did that front end squeak! I know that the ball joints are greased, maybe they were supposed to grease the bushings as well? Anyway, mine is a little better now, I hope that it is getting better with time/driving....?
    CommieHook
  4. captainmack
    captainmack Quad Door
    I had the most embarrasing squeek... pulling into a parking lot, folks would turn and stare. :( I replaced the entire uca assembly bolts and put in rollers perches to be sure.... no more squeek. I am pretty sure it was the bolt/bushings in the uca. I feel you pain too... no amount of spray would fix it.
