Another starter question.
Discussion in 'New Members Forum' started by f1ford1, Apr 3, 2012.
  1. f1ford1
    f1ford1 New Member
    Hershey Pa.
    1971 Grabber
    I have a newer 5.0 with the origional C4 going into my 71 Grabber.Which had the 250 I6 in it. I have a 157 tooth flexplate with 50 ounce imbalance. Now my question. The older single wire starters have a 9 tooth drive gear and the newer 2 wire starters have a 10 tooth output drive gear. Which starter is correct or doesn"t it make a difference? I started this project 8 years ago so I am trying to remember the things that I have read back then. I appreciate the help.
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Welcome to the site!!!!! Either starter will work.....
  3. f1ford1
    f1ford1 New Member
    Hershey Pa.
    1971 Grabber
    Thank you and Thank you.
