another tire size question
Discussion in 'Technical' started by j miller, May 12, 2005.
  1. j miller
    Polson, Mt
    does anyone know if a 275x60x15 tire will fit in a stock wheel well? the rims will be 15x8 with 4 inch backspacing. i am considering running 255's or 275's . the car is a 71 4 dr w/ stock length rear axles. no mini tubs.
  2. Maverick Man
    California
    yes... but roll the fenders
  3. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    I have 275/60/15 in the back....didnt have to roll the fenders:hmmm: ..used a BFH on the inside of the wheel wells.
  4. scooper77515
    What is the biggest you can get under there without BFH engineering? I have 245 and seems like I could easily get 255, maybe 265 under there.
  5. Maverick Man
    California
    i'd roll them cuz if the leaf springs are weak they will rub... or if your car is as low as mine it will rub too.
    without BFH 245 easy.
  6. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Hey Jason, What rims are you planning to run on there?
  7. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    The answer to your question is going to depend on the backspacing of the wheel that the tire is mounted on, whether it be 3-3/4", 4", or 4-1/4"...
  8. stmanser
    Davenport, Iowa
    i want the 255 tires....15x8 rims....what back spacing will i need??
  9. 74MAV
    74MAV Gearhead
    St. Louis MO
    74 Maverick
    Just did 255/60 R15 Four inch backspacing worked good on my 15X8
  10. Aeon 71maverick
    Aeon 71maverick Member
    Brookings, SD, USA
    Maverick, 1971 2Dr, Green. HighPerf 302 & TCI C4. Interior Black.
    :2cents:
    I just put BFGoodrich T/A 255/60/15 on cragar street stars 15x8 reversed 3 1/2 inch Backspace. lifted backend, this setup DOES clear lakewood traction bars.
    1971 2dr maverick, rearend/springs from 1976 4dr mav.
    GOOD FAT TIRE RIM COMBO imo
  11. stmanser
    Davenport, Iowa
    cool
    thats the setup i was looking for...and i have lakewoods as well...
  12. Aeon 71maverick
    Brookings, SD, USA
    glad ya like it. :evilsmile here's the full scoop.
    front 14x6 (to maintain correct geometry) BFG 195/60/14 on cragar streetstar
    summit
    Part# BFG-84497 / CRR-341-4612
    Rear 15x8 BFG 255/60/15 on cragar streetstar
    summit
    Part# BFG-71728 / CRR-341-5816
    lug nuts CRR-278834 (very nice)(need REALLY deep ones)
    Hope ya got a good torq wrench
    cost about $900 for all tires/rims/lugnuts/mount/balence/shipping
    i posted a pic of this SOMEWHERE called newrims.jpg (error on page, can't upload a new one)
  13. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    What does 255/60/15 mean?:huh:
  14. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    255 is width of the tire, 60 is the aspect ratio of the tire like its 60% of the width of the tire, and 15 is the tire size
  15. j miller
    Polson, Mt
    part time--- i looked it up and here goes (per cooper tire web page)
    255= width of the tire in millimeters
    60= ratio of height to width (aspect ratio)
    15= wheel diameter in inches
    i am thinking of going with the american racing outlaw 1 brushed aluminum. i have a friend who is thinking of changing wheels and i should be able to get them fairly cheap. if he does not sell then even new they aren't that expensive.
