Another wiring question 72 comet
Discussion in 'General Maverick/Comet' started by Lucifer, Nov 28, 2021.
  1. Lucifer
    Lucifer Member
    Canada
    1972 comet
    I’m at a loss as to what these wires are for looks like they go through the fire wall , I’ve searched for hrs don’t know how to use schematics not even sure if that’s how it’s spelled. But it looks like a round grommet that fits a hole in the firewall.
  2. William623
    Orlando
    1973 ford maverick grabber
    Did the car have a factory automatic floor shifter? Looks like the wiring harness for the transmission mounted neutral safety switch.
    Craig Selvey and BBMS18 like this.
  3. Lucifer
    Lucifer Member
    Canada
    1972 comet
    Could have ,it definitely had a column shifter cause it’s still in there less the shift part I will try decoding the vin just got the battery installed back in the front out of the trunk I can start testing wires today
  4. Krazy Comet
    There's no transmission info in VIN.
    The data tag will have trans type info but not whether it was floor or column shift.
  5. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    Do a Google search for 1972 maverick , firewall, wiring. Gather information, wiring takes research. You will need a ford electrician. The wires are cut, it will take a pro wiring Man. Not necessarily an expensive one. This Wiring has been patched before, and it will be customized some more unless you by new, all the way.
  6. Craig Selvey
    Factory floor shift cars had THIS hole punched out in the firewall.
  7. dyent
    dyent Member
    vancouver bc
    How many wires are there and if you could let us know what their colour markings are, might be able to find out what it is for.
    David
