Antenna
Discussion in 'Technical' started by maverick75, Jul 5, 2005.
  1. maverick75
    does anyone know how to remove them...the other day @ the junk i triend to remove one but i got so frustated trying to take it off i just messed it up
  2. Burlap1
    Burlap1 fat lazy truckdriver
    Urbana ny-wine country finger lakes wines are best
    1983 f-150 4wd,1971 cougar parts car,1973 maverick parts car,1970 maverick formerly a gramma's grocery getter,1984 f-250 460 powered,1976 f-350 u-haul,and some chevy's
    a lot of antennas bolt on the underside of the fender.some have a slip nut that goes over the assembly.try to get them from underneath the fender.good luck.
  3. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    it has a cover that you can put a small screwdriver under and pop off, the wire gos to back of radio and you can feed it thru the hole on the fender/frame
  4. bmcdaniel
    If it's the solid mast type pop off the top cover and there are sheet metal screws that hold the base to the fender, at least that's how my 70 was.
  5. rob's74cometgt
    rob's74cometgt Member
    Chilliwack, B.C., Canada
    74 Comet GT
    Then you'll need to make sure it's disconnected from the radio and pull the grommet out of the right hinge pillar where the cable goes through. You can then pull the whole cable out from the hinge pillar and then through the hole in the fender.(y)
  6. Erick-Mav
    Erick-Mav Maverick Punk
    Oceanside, CA
    71 Grabber-Factory V8 w/3spd, 72 Maverick-351 Procharged for Strip, 71 Comet GT-331/4spd
    The cable comes off from the antenna base, but it gets rusted and won't come off too easy. I used wd40 and a set of pliers. The first one I tried to get at the junkyard I pulled the wires out of the antenna bottom and messed it up.
  7. maverick75
    Thanx everybody 4 the help(y)
  8. stmanser
    Davenport, Iowa
    mine has 4 screws going straight down to fender....take the screws out....pull the cable off the radio and pull the cable gently through the interior until it comes out the fender
    thats mine at least... 71 mav.... stock antenna...took it off to primer the car
