anybody put a gas sump on 71 maverick any pics
Discussion in 'Technical' started by jaxster010, May 16, 2012.
  1. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    trying to intall a sump on my gas tank anybody ever done this and have pics and could tell me the difficultly level
  2. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    I've got pix of mine, but it's an earlier Mustang tank so not sure it's do you any good...
  3. Bryant
    the biggest concern about putting a sump on a gas tank is the welding on a tank that has any gas vapor left in it. it can explode.
    the best thing to do is to get a new tank that has never had gas in it and put the sump on that.
    in my experience a sumped gas tank doesnt work well with fuel injection. what happens is when when you turn the fuel will slosh to the sides of the tank and the fuel pump will suck air and cause the motor to shut off. it is very annoying.
    most people will drill several large holes in the floor of the tank where the sump covers to act as baffels but this only helps in straight line acceleration.
    i have not done this yet but i plan on cutting an I in the floor of the tank and folding the sides up at about 45 degree angles to capture the fuel as it flows side to side in turns. i have not done or tested this method yet but i expect it to work allot better than just holes.
