Anyone know?
Discussion in 'General Maverick/Comet' started by Matt72Mav, Jan 30, 2012.
  1. Matt72Mav
    Matt72Mav Member
    Memphis tn
    1972 Ford Maverick
    So I bought a 72 Maverick with no motor or trans from a guy and I'm curious is this the 302 model. The vin says its the grabber model. But my real question is how can I tell if it's the 302 model.
  2. tody
    tody Member
    cologne, germany
  3. Matt72Mav
    Matt72Mav Member
    Memphis tn
    1972 Ford Maverick
    Ok so it's a L which is 6cyl 250. How hard would it be to put in a 80-70s model 302 and c4 trans. Cause I have the car and that 302 with the trans.
  4. maverick75
  5. Matt72Mav
    Matt72Mav Member
    Memphis tn
    1972 Ford Maverick
    Do you know where I could price the stuff on the needed list on that first link?
  6. maverick75
    No one sells a replacement kit, but you should probably expect to pay $250-$400 for a complete kit. Depending on what it contains.
    Post a wanted ad in the classifieds, i'm sure several member have V8 swap kit's they'll sell you. If not you can try and find each part at junkyards, ebay, classifieds, etc...
    302 V-8(you already have one)
    302 MAVERICK motor mounts (available at any parts store $10-20 each)
    302 frame mounts (you can get a new set from critesperformance.com $99, or buy a used set $50-99)
    V-8 Engine cross-member(TOPORANGER sells an aftermartket one on here, or buy a used one $20-50)
    Double hump transmission cross-member(Buy a used one, no one make a new one $20-60)
    V-8 Power steering bracket (only required if you want PS, also it depends on if you're runnign AC or not.)
    Longer Power Steering Hoses(Only if you're running PS, available at parts stores)
    V-8 Alternator bracket (buy used $5-10)
    V-8 Starter (available at any parts store $35-100)
    250 I-6 or small block ford V-8 bell-housing (you already have it)
    250 I-6 or 302 Maverick radiator (Although I got away with using the 200's radiator)
    (Available at parts stores, or better yet get the champion maverick radiator from eBay)
    Fan Shroud (not necessary, but unless you are using an electric fan it will be missed)
    V-8 Pulleys -Power steering/crankshaft/fan/water pump(The ones you have should work, depending on what fan you want to run. Also it depends on what water pump you have.)
    Front sump oil pan (Double or rear - sump pans won’t work without frame modifications)(available at any parts store $50-100)
    V-8 throttle cable (optional)
    V-8 wiring harness ( or just build one)
    V-8 kickdown linkage(buy used $10-30, or get an aftermarket Lokar one)
  7. Matt72Mav
    Matt72Mav Member
    Memphis tn
    1972 Ford Maverick
    Most help I've ever got thanks much I'll keep ya posted on my build. Thanks again.
  8. yellow75
    Tillamook Oregon
    I have a complete v8 conversion set up for sale, it includes the frame stands specific to Maverick/Comet, belly bar, transmission double hump crossmember (aids in installing dual exhaust) throttle cable and all the nuts and bolts needed
    $185.00 shipped if interested
  9. yellow75
    Tillamook Oregon
    You will also have to get exhaust of some sort, headers or factory that will fit a Maverick
  10. mrbrooksy
    mrbrooksy Retread
    Motor city
    72 maverick,99 cherokee,2000 cherokee.80 suzuki ts 250 and a minivan
    I have a question about the double hump crossmembers. Maverick factory part or swiped from another ford? my v8 has a single hump factory as far as I know?
  11. yellow75
    Tillamook Oregon
    Double hump tranny crossmember is original on a v8 Maverick
  12. Matt72Mav
    Matt72Mav Member
    Memphis tn
    1972 Ford Maverick
    If I buy that kit from you what else will I need to drop the 302 right in?
  13. yellow75
    Tillamook Oregon
    It depends on how far you want to go with it depending on what you have already that will work
    Exhaust and radiator, which your radiator should work, motor mounts maverick75 pretty much hit it on the head with his post, the parts I have will make it so you can put the motor in and the rest is upto you.
    I do have the exhaust manifolds but would recommend going with a set of Hooker 6901 headers, they fit nice the only issue with them is if you have a column shifter the linkage does not work, also depending on whay year 302 you have it may not have the hole in block for automatic linkage to bolt to.
    Most of these engine swaps require some kind of creative work to make ends meet
