...anyone use these...
Discussion in 'Technical' started by 71gold, Jan 15, 2011.
  1. 71gold
  2. injectedmav
    injectedmav Member
    Georgia
    Ford has been using this technology on some applications since the late 90's and it seems to work fairly well. The only issue I see is serviceability. I'm assuming if they're like the OEM's, you cannot remove them without cutting them. Then you'll have to buy another $5 clamp every time you take the hose off.:hmmm:
  3. ra3psd
    ra3psd Member
    texas
    72 maverick grabber
    Saw several guys in Tyler, Tx a couple of months ago that had these on their engines. I asked them about them and they all love them, but as stated above, if you have to change out a hose, they have to be bought again.
  4. bmcdaniel
    bmcdaniel Senile Member
    How do you cut them to remove?
  5. darren
    Be a real clean looking install. I may just try those. I figure just have an extra couple on hand for the upper rad hose. In case of fan removal etc.
    Sure would clean up the look of my fuel lines. Just leave a regular clamp at the carb.
  6. 71gold
    my line of thinking also...:thumbs2:
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    We use them on alot of custom street/hot rod applications where I work..... They give a very clean appearance and I have not seen one fail yet.....
  8. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    I also like the looks of them and it wouldn't bother me to cut one off and then have to replace it but i would be afraid i might cut the hose in the process wich would be an added expense:scratchchin:
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Pros- Clean, simple. Lots of big trucks use them now, so they have to be durable.
    Cons- One time use, have to be cut off to remove. Since you change engines like I change socks, you're gonna go through a bunch of them!:rofl2:
  10. Dave B
    Cool!! I didn't know something like that existed...I'm going to order a few, for sure.
  11. bmcdaniel
    I see Rock Auto sells them for about half the price of Street Dreams.
  12. bmcdaniel
    GATES Part # 32941 [​IMG] Thermoplastic - Size SB41 (Nominal Hose I.D. 1 1/4", Fits Hose O.D. 1 1/2" to 1 3/4") (Only 11 Remaining)[​IMG]
    $2.68Add to Cart [​IMG]
  13. mojo
    Good price - less than the screw on's around here.
