Aod question
Discussion in 'Transmissions' started by gwil81, Apr 27, 2019.
  1. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    When running a aod what tranny lines do you use? I have a aod in my car running but I use rubber lines and I want to do hard lines.
  2. Krazy Comet
    Most factory lines are going to be similar with cooler connections in side of radiator(only ones I remember used crossflow radiators). Being as lines route beside engine most any line should be near the lower part of radiator where they can be coupled with a short piece of hose.
  3. 71gold
    I use hydraulic hose...it can handle the heat, pressure and oil.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Some would say you lose the added cooling from the steel lines but I have never had an issue using hydraulic hose. It's so much easier to route and holds up very well.
  5. 71gold
    mine go to a transmission cooler mounted to the rear.
      File size:
      141.2 KB
    RMiller likes this.
