AOD question
Discussion in 'Transmissions' started by signal20, Aug 28, 2009.
  1. signal20
    signal20 Paul VanSteen
    Spring Hill, FL
    I have a 86 302 in my 71 mav. The 302 and aod are from a 86 t-bird. How do I set up the tv cable to a 4bbl carb. What cable should I use? Can I use the cable from the tbird as it was fuel injected? Please help
  2. 71gold
    Lokar has what you need..:Handshake
    TV/TC bracket - SRK- 4000 -
    Throttle Cable-TC1000U
    TV Cable - KD-2AODHT - (Holley Carb.)
    TV Cable Corrector - Sum-700202
  3. signal20
    Spring Hill, FL
    Frank,
    Thank you.
    I should have just asked you first.
    Was it hard to adjust?
    Thanks again
    Paul
