are the 170,200,250 distribitors the same?
Discussion in 'Technical' started by Russ, Dec 6, 2005.
  1. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Do they swap from one engine to the other? thanks
  2. Acornridgeman
    Wisconsin
    Yes, they are interchangeable. There may be slight differences in the weights and advance curves, but they will swap between motors.
  3. Jamie Miles
    Alto, GA
    I've had a few
    Yep, they will change. I was running a 200 Distributor in my 250.
  4. Russ
    New Brighton PA
    74 "Bruiser" Mav-
    Ok thanks. Russ
  5. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    It depends on the years but I`m purdy sure that 70 up all interchange. You may want to ask on fordsix.com to be sure .
  6. Jamie Miles
    Alto, GA
    I've had a few
    They all interchange back into the 60's. My distributor is out of a 1983 200 and I'm running it in a 1974 250. I read of people doing Duraspark conversions on 60's Mustangs all the time and using Distributors off late 70's cars in 60's 170's and 200's.
  7. Mavaholic
    I put a DuraSpark set up out of a Maverick into a 200 six in my 67 Mustang I used to own.
