Audio...
Discussion in 'General Maverick/Comet' started by Jsquared8, Feb 28, 2005.
  1. Jsquared8
    Jsquared8 Member
    Missouri
    1974 Maverick
    Does anyone have a good sound system in their maverick. Where is the best place to mount the front speakers, the rear? Would a new stereo install easily or would i have to do things with wires, would the stock antenna work even though it had an AM radio?:huh: What would i have to do to put a sub in the back, i was thinking of putting in a spray in bed liner. thanks.
  2. Maverick Man
    California
    depends on what you call good? IMO unless its got a subwoofer it aint good ;)
    front speaker would be best mounted in the kick pannels. the further forward the better.
    for the rear the deck lid is fine.
    as far as the stereo you would need to cut the stock raido bezel to fit the new single DIN radios.
    for wires you can tap into the stock radio harness but you would need to wire up for the new speakers.
    the current atenna will work.
    sub will be nice too.. but you will need an amp and you will need to route a powerline streight from the battery to the amp where ever you mount it. i would also suggest that if you do get an amp make sure the radio has RCA outputs even better one with a sub output.
    if you have any other questions i'd be happy to answer them.
  3. JeffScoggins
    JeffScoggins A.k.a. Conan Jr.
    Lake Charles, LA
    1970 Ford Maverick
    Talk to CountryMav (Preston). He knows a good bit about stereo.
  4. Jamie Miles
    You need an 8 track player. (y)
  5. Jsquared8
    Jsquared8 Member
    Missouri
    1974 Maverick
    "i would also suggest that if you do get an amp make sure the radio has RCA outputs even better one with a sub output."
    I got teh Soney xplod cdx-fw500 and it has the sub out, so would i still hook that up to the amp?
  6. BIGbully
    BIGbully Maverick Maniac
    Omaha, Ne
    If you decide to get an amp, which I highly recommend, you should definitely invest in a higher output alternator based on how much amplifier power you intend to run.
  7. Jsquared8
    Jsquared8 Member
    Missouri
    1974 Maverick
    whats the output on the stock alternator?
  8. Maverick Man
    California
    i think on cars with air they were 65amps
    you don't need any more then that if your just running an stock motor, an aftermarket radio, 4 speakers and not running anything bigger then a true 150 watt RMS amp.
    you should be fine.
  9. Mavaholic
    2 1/2 watts of Ford built AM/FM mono, baby!!!!:D It dont get much better than that!
  10. Jsquared8
    Jsquared8 Member
    Missouri
    1974 Maverick
    Mine dont even have FM, just AM. (for now):)
  11. Maverick Man
    California
    my cars to loud i woundn't be able to hear the raido :rolleyes:
  12. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I put the stock AM back in mine, cant hear it anyways. FLOWMASTERS!
    Dan
  13. Jsquared8
    Jsquared8 Member
    Missouri
    1974 Maverick
    i went to wal-mart tonight to look for one of those install kits with the trim that goes around the head unit and they dont have any for older fords. does anyone know where i can get one for my maverick?
  14. Mercurycruizers
    Venetia, PA
    I have a JVC Am/Fm/Cass with detachable face. I have 2 speakers front (kickpanels). 2 speakers rear (rear deck) & a 10" subwoofer in the trunk with my 12 disc CD changer. I also have an amp under each front seat (1 powers the 4 speakers & 1 powers the subwoofer. It can be done......
    Like they said, you'll have to cut out the faceplate to accept the newer radios....
  15. 77mav302
    77mav302 Member
    Spokane WA.
    77mav302/2dr, 70mav 2dr
    my 77 has the factory am/fm 8 track, is that good?
