auto to manual conversion
Discussion in 'Transmissions' started by torquingturtle, Oct 26, 2021.
  1. torquingturtle
    torquingturtle Member
    queenstown, MD
    '73 2 door Maverick, 302 auto
    Hey there, just joined this forum. I've had my 1973 v8 Maverick 39 years, my dad bought it new. It had a column shift c4 which I moved to a floor shift way back when I was a kid. Anyway, I want to convert to a manual, maybe t4, so I'm looking for any direction for this other then the tremec conversion kits? Again, it has a c4 auto, so I would need everything.
    Thanks,
    Mark
  2. 71gold
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hello Mark :
    Welcome to the forum ! I HAVE a T5 Five Speed Tranny that is in good condition when I took it out . I replaced a T5
    AND 5.0 Fuel Injection Setup in my 70 Maverick NEW and I have the working tranny I removed on my garage floor. If you're interested I'd take $ 1100.00 for it Plus Shipping from Deland, Florida . Lemmeno .
    Cometized
    Chip
  4. dyent
    dyent Member
    vancouver bc
    Hi Mark, welcome to the forum! You can also check out this site for more information on T5 conversions........
    call Bruce, he has helped many of our members, myself included, going hydraulic will eliminate many of the hard to find mechanical linkage etc.........good luck!
    https://www.moderndriveline.com/
    Also, check your pedal support bracket to see if it has 5/8" shaft with "red" clip securing it on the end, if this is what you have, then installing Clutch Pedal/Brake assemble will be easy. If you have a shaft with bolt and nut, then you will have to swap out the pedal support bracket.......
    If you can post a picture of your current pedal set up, I can let you know if you can use your existing brake pedal, or if you have to locate correct one for going manual, Modern Drive line has clutch pedal that you can use if you are going hydraulic, otherwise you may have to post ad in "wanted" section for Clutch Pedal etc....
    David
    CA189HJN likes this.
  5. torquingturtle
    queenstown, MD
    Thanks!
  6. torquingturtle
    queenstown, MD
    Thanks David, I'll check it out.
  7. torquingturtle
    queenstown, MD
    Thanks for the offer!
  8. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Welcome, nothing like a manual shift to make you feel like you're really driving the car.
  9. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
  10. Powerband
    Powerband Member
    NY's \H/
    ... and I never learned how to drive an automatic ...
    have fun'
  11. torquingturtle
    queenstown, MD
    (y)
  12. torquingturtle
    queenstown, MD
  13. bmcdaniel
    bmcdaniel Senile Member
    :Welcome: from south central PA.
    T5 is definitely fun. I put mine in back in 1997 or 98.
  14. McQuick
    McQuick Member
    Chula Vista, CA
    1974 Maverick 250 Auto
    Hello. Jumping in here a few years later on....
    I have a '74 250 auto, want to do the 302/manual (T5) conversion. I'm a total novice!
    When I bought the car, the guy gave me a manual pedal bracket; rusty, but all there except the clutch pedal return spring. The auto bracket on my car is a bolt and nut type, which you say cannot do the easy swap. But I'm not ready to give up, because pulling that whole thing seems like a MAJOR EFFORT for this creaky old novice!
    On the existing auto bracket, I can feel two holes right about where the clutch spring brackety thing goes (at right in pic below), so I think that would swap over easy enough.
    However, the pedal shaft trunnions (?) on the manual bracket would have to be swapped onto the auto bracket....is there any way to remove them? They do have flats on the outer piece, I'm tempted to try to rotate that....or maybe they were press-fitted at the factory?
    I would think if I could get those trunnions and spring bracket onto the auto bracket, the pedals would go in easy-peasy.... what do you think? THANKS
  15. bmcdaniel
