B&M starshifter
Discussion in 'Technical' started by comet 75, Nov 12, 2003.
  1. comet 75
    comet 75 comet 75 swap 302
    Quebec
    mercury comet 1975 302
    What it means when they say : Cannot be used with reverse pattern valve body.
    site link
  2. Mavaholic
    Reverse pattern goes:
    park, reverse, neutral, 1st, 2nd, and 3rd
    where as standard is:
    park, reverse, neutral, drive (third) second, first
  3. comet 75
    Quebec
    In what case do you found this patern and if I put it on my comet with c4 trans. do I need to reverse the on trans. arm like a column to floor shift conversion ??
  4. Old Guy
    Old Guy Member
    The reverse pattern valve body is normally for racing only and is full manual shift. Has to be purchased from an aftermarket source such as TCI or Jeg's. All factory valve bodies are foward pattern and automatic shifting unless someone has modified them. It will work fine with your trans as is.
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    reverse valve bodies/////
    They also keep you thinking!
    Some many years of "slamming" forward on that shifter!
    Had to change my whole driving style when I went to a reverse vavle body!
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I put one of those starshifters in my Cyclone. Works good!
    Dan
