Back Pressure From Oil Question
Discussion in 'Technical' started by Nightshade, Jun 26, 2007.
  1. Nightshade
    Nightshade Member
    Oregon
    1974 Comet
    I own a 74 Comet. It seems like there is a lot of pressure in the engine - blowing oil out through the dipstick and blowing oil into the air filter as well.
    Any thoughts or ideas why it's doing that?
    Mark
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    It could be as simple as a bad PCV valve if there is just a little blow-by.
    However, if it is bad, the cause is more often broken or badly worn piston rings.
    If it pushes your dipstick up and shoots oil out at higher rpm, then you probably need to make rebuild plans.
