backfire
Discussion in 'Technical' started by metalnate, Jul 18, 2010.
  1. metalnate
    metalnate Member
    Sioux City, Iowa
    1972 Maverick Grabber
    what would cause the car to backfire? through the exhaust not through the carb...
  2. Craig Selvey
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    do you have any exhaust leaks
  4. simple man
    simple man Member
    Bunnell,Florida
    If you're still running points,a possible bad condenser. If duraspark a possible bad module or pickup coil. Anything that interrupts the ignition for a moment puts fuel vapor and air into a hot exhaust system. I had a module go bad,where it just hiccuped for a second and blew the muffler apart!
  5. metalnate
    metalnate Member
    Sioux City, Iowa
    sure do needs donut on passenger side! thanks!
  6. PaulS
    Fix the leak, it will most likely fix the backfire.
