Baer Brakes
Discussion in 'Technical' started by Maviboyz, Oct 14, 2011.
  1. Maviboyz
    Maviboyz Member
    Bay Area California
    76 maverick stallion, 72 cleveland comet, 70 winsor maverick, 73 hurst comet
    Any one got Baer brakes on there maverick or comet?
  2. Maviboyz
    Maviboyz Member
    Bay Area California
  3. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    If I had the money!
  4. olerodder
    olerodder Member
    NorCal
    Just a question, why Baer and not Wilwood or Aerospace Components?
    http://shop.aerospacecomponents.com/4pistonheavydutyfrontprostreetkitmustang70-73.aspx
    I couldn't get the Wilwood site, but I just put some Aerospace front/rear disc's on my Maverick..........although the car is drag only car, fit on the spindles and really saved about 50lbs off the front end. Fit on original spindles, lines hook'd up with their kit...................IMHO
  5. maverick75
    willwood makes a kit for our cars, all the brazilian guys run Baer brakes. But who knows if they got the same spindles as us. They also run dagger(sp?) wheel, which I love.
  6. olerodder
    olerodder Member
    NorCal
    Well, Wilwood makes a direct bolt on kit for our cars as does Aerospace Components..................I guess I don't see any difference from them and Baer.
  7. 73grabber331
    73grabber331 Member
    1973 grabber 289 5sp
    i have 13inch rotors and mach one brake caliper setup the one with the horse. same setup as the cobra 13in. i just used a mounting bracket from street and track
    not sure if your talkin bout the baer 13in setup
    you can get it to fit but you have to get mounting bracket from street & track
    they sell the whole kit u need bracket with hardware, steel braided brake line,
    1in spacer if your running 94-04 wheels like bullets
    3in studs for the spacer
    if your running oriiginal offset wheels like the 4 inch back spacing you wont need the
    spacer real good set up i love mine bolted rite up no problems
    the bracket bolts up to your original drum spindle
    if you have granada brakes all ready they also make a bracket to fit 13in rotors
  8. mojo
    73Grabber331 do you happen to have any pix of the setup? Sure wud like to see them.
  9. 73grabber331
    73grabber331 Member
    pics ok i will get them up when i get off work 5pm
