Ball joint removal. HELP!
Discussion in 'Technical' started by ajk, Oct 7, 2009.
  1. ajk
    ajk Member
    calgary
    Using a pickle fork I have removed the upper and lower ball joints, all except the upper ball joint on the driver's side. No matter how much prying and jostling, it remains attached to the spindle. Any advice or ideas?
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    add a little heat, not too much, to the ball joint rod and BFH.....
  3. rthomas771
    Heat will expand the stud making it tighter. Drive the fork in place and smack the spindle where the stud passes through with a hammer. The shock wave will free the ball joint.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I never use a pickle fork use a BFH and shock them loose.
  5. rthomas771
    He done damaged the ball joints by using the fork anyway. Might as well use the fork now so a lesser blow will free the ball joint. If reusing the ball joint...shock wave and gravity is the best way to save the part.
  6. ray
    ray Member
    portland
    71 grabber
    wipe all grease off with some thinner or acetone, put pickle fork in place, heat the outer pitman arm with a small propane torch, make sure you have a bucket of water wet rags or a fire extinguisher for saftey immediately after heating hold an ice cube carefully on the bolt shaft without touching the pitman arm for about a minute or so, then whack the fork and wa la.......
  7. Resto
    Resto Benders Evil Twin
    Yuma AZ
    I hate the fork. I just hit it from both side with 2 2lb hammers. If that doesnt work I use a Map torch then hit it again. The ball joint is no good now.
  8. blugene
    It's been two years.. Surely he got it off by now. :biglaugh: :burnout:
  9. Bob Wiken
    Fayetteville, Arkansas
    LOL Gene ( msg is too short)
  10. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Always use a hammer on ball joints ,no heat no pickle fork, hit it as hard as you can with a big hammer, one good hit is equal to a hundred little hits
  11. bmcdaniel
    I use a home made press I made from some threaded rod and some coupling nuts. Fits between the upper and lower bj studs.
