battery cable for trunk mount?
Discussion in 'Technical' started by flynbrd, Jun 2, 2011.
  1. flynbrd
    flynbrd Member
  2. PaulS
    That would be great for an amp but for your starter (drawing up to 250 amps) you are going to need some 0 AWG or 00 AWG cable. I opted for the larger 00 AWG cable so I am sure there is no appreciable voltage drop in the cable. (less than 0.5VDC when cranking)
  3. rthomas771
    2 gauge is way too small to pull a starter. I'm running a 00 in my Falcon.
  4. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Internet fantasies... :rolleyes: I've had 4 AWG in my Buick GN powered S-10 swap since '03 and it never gives me any problem starting. Of course, that's only a lowly 6 cylinder. Running 24 PSI boost. Pulling 12.0's @ 3750# on street tires.
  5. superlead76
    superlead76 Member
    Tampa, FL
    1972 Maverick Grabber 347!
    Just buy the kit from Summit.
  6. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    Ditto x 2!!!
  7. Bob Wiken
    Fayetteville, Arkansas
    I seem to remember something about using welding machine wire from some post as an inexpensive alternative. Just a thought
  8. 71gold
    that's what i have in my car...:thumbs2:
  9. bmcdaniel
    bmcdaniel Senile Member
    My company makes automotive battery cables, just about all of our customers specify welding cable because it's so flexible. I, too, would use 2/0.
  10. rthomas771
    Reason welding cable is better is because it has more strains than battery cable when both cables are the same gauge. Same reason you wouldn't use a single solid wire
  11. injectedmav
    injectedmav Member
    Georgia
    X2 on the welding cable. 2ga, stock 93 mustang gear reduction starter. has worked fine since 99, daily driven.
    X2 on the strand count. it's easier to work with and less likely to have significant voltage drop under load.
    the welding wire insulation isn't as chemical resistant as automotive wire but as long as you don't let fuel or oil sit on it, it is just as good as anything else.
  12. PaulS
    More strands does NOT make the wire more conductive, just more flexible.
    The conductivity is determined by the volume of copper not the number of strands. A solid copper conductor would be smaller than cable simply because there is no gaps between multiple conductors. Welding cable is slightly more bulky than normal cable but the jacket is softer and the extra (smaller) wires makes it flex easier and into tighter bends.
  13. injectedmav
    injectedmav Member
    Georgia
    Sorry, I mis-stated that. What I meant was that a 2ga fine stranded wire will carry more current with less voltage drop that a coarser stranding of the same physical size due to the fact that there is a greater volume of the conductor in a given wire cross section.
  14. flynbrd
    flynbrd Member
    so go get 2/0 which is 2 awg wire from a welding supplier shop? Anyone know how many feet I'll need roughly. Best mounting location? I would think center behind the backseat would be best but routing could make that a problem. :hmmm:
  15. injectedmav
    injectedmav Member
    Georgia
    That's where mine is. the positive runs the rocker panel inside the channel that the wire loom on the other side goes, the negative goes through a hole and grommet in the trunk and follows the side of the tunnel to the starter bottom stud.
    2/0 is actually 00, much larger than 2ga.
