Battery tray
Discussion in 'Parts Interchange' started by Jerry, Oct 2, 2004.
  1. Jerry
    Jerry Member
    Woodstock, GA
    77 Maverick 2dr 302, 74 LDO
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Yes, but I got mine for 12 bucks from Auto Krafters. That one on eBay is already up to $15 and may go higher before it's over...
  3. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    The seller is Auto Krafters. It would be better not to bid on their ebay auctions. but instead contact Auto Krafters directly and get it cheaper.
  4. T.L.
    T.L. Banned
    Southern Colorado
    I wonder why AutoKrafters is doing eBay auctions? Business must be slow...
  5. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    Auto Krafters has been doing buisness on E-bay for years. That's where I got my windshield gasket. BTW at the time it was cheeper to buy it on e-bay than from the catalog. As in ANY E-bay auction you must know what the item is worth before bidding.
  6. rayzorsharp
    Very true Russ...I've bought several items on eBay from AutoKrafters and saved money.
  7. T.L.
    T.L. Banned
    Southern Colorado
    Learn somethin' new every day...
    :slap:
  8. Mavaholic
    Just remember that on all these trays, you have to cut your mounting bracket off your battery tray and weld it to this one. I always use the 67-70 Mustang trays.
  9. Earl Branham
    Lugoff, SC
    I cut the bracket off the old tray, and bolted or riveted it on. Use lock and flat washers, and it won't come loose. Makes it easy if you have to remove it for any reason.
