Battery Won't Stay Charged
Discussion in 'Technical' started by Krax, Nov 30, 2010.
  1. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    I have a brand new alternator and battery, but it just won't keep the battery charged. It's hooked up right, and it's making me mad cause I thought I fixed it but I guess not, anybody know what could be the cause of that?
  2. Acornridgeman
    Wisconsin
    What is the charging voltage at 1500 rpm? Should be between 13.8 and 14.2 volts. If that is OK - your new battery might have a bad cell. If lower than 13.8, you have issues with the voltage regulator, alternator, or wiring for those 2 items.
    Test the voltage and post back.
    :thumbs2:
  3. 65 comet
    65 comet Member
    Colorado
    65 Comet Caliente Hrdtp, 65 2+2 Mustang Fastback 4 spd 53 F100 project 67 Ford 1 ton 4x4 project
    :hmmm: Do you know if there is a short that is drawing on the battery? Check the draw buy disconnecting + cable and use a multimeter between cable and post. Is the Regulator good? Jump start car and see what voltage and amperage is being put to the battery. You can check Alternator buy starting car and removing cable from battery, see if it will keep running on just Alternator output. If not have it checked, could be defective. If you can, do a draw down test on battery to see how fast and well it recovers, it may be bad. even new stuff can be defective. Good luck. :tiphat:
  4. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    It might be the voltage regulator, gotta wait til my roommate gets home so i can ask where his testers at
  5. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
  6. Krax
    Krax Member
    Stephenville, TX
    1973 Ford Maverick
    If I take off either connection to the battery it dies... Good thing I got a lifetime warranty on my alternator. Ima check all that other stuff too.
  7. Acornridgeman
    Wisconsin
    That pretty much tells you where to look ......... :thumbs2:
  8. PaulS
    Disconnecting the alternator with your engine running is not a test for an alternator.
    They used to test generators that way but all it does with an alternator is spike the voltage to over 90 volts. It can ruin the alternator, regulator and most electronics in your car.
    There are specific tests that you can, and should, run to diagnose charging problems.
