Bell & Flywheel Question
Discussion in 'Parts Interchange' started by Speedy, Feb 19, 2014.
  1. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    Hi,
    I'm in the process of a 302 manual tranny upgrade in my Comet. It was originally a 250 automatic. The bell housing I am using is a cast iron # D1TA 6394AA. From what I can tell this is a 351 bellhousing utilizing a 164 tooth flywheel. Everything I've read says this will work. My question is concerning the flywheel. For some reason I was thinking I pulled this bell and flywheel off of a six cylinder. If this is the case, could there be a problem with the balance on the flywheel? My 302 is a 1979 302 so I beleive it should be a 28 oz. Is that right? How can I determin if my flywheel is also a 28 oz? Your help is apreciated.
    Speedy
  2. lm14
    lm14 Member
    Iowa
    28 oz will have a weight about 3" long welded/bolted to the flywheel or it will have a large area that is removed to lighten one area drastically.
    Your 6 cyl flywheel should be neutral balance with it looking the same all the way around and no additional weights.
    SPark
  3. Speedy
    Speedy Member
    Dallas, TX
    '71 Comet GT
    OK, I'll check it out tonight. Thanks...
  4. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    A 351w uses a 28oz bal. flywheel on the older models,some of the later 302s use a 50oz flywheel.Not sure about the newer 351s.
  5. lm14
    lm14 Member
    Iowa
    All 351's use a 28oz
    SPark
  6. Krazy Comet
    I'll guess the big 300 six would use a 164 tooth bell & flywheel, but I'm about 97% sure it will be zero balance(no weight or cut outs)... The 1980 & earlier 302/5.0 are 28oz balance, all 351/5.8 are 28 oz balance...
  7. lm14
    lm14 Member
    Iowa
    ALL 6cyl engines I am aware of are -0- balance, you don't need it until you start opposing cylinders in a "V" formation because forces are happening in 2 planes then. You can balance the parts of a 6 cyl but the crank stays neutral from my experience. Whenever we needed a -0- balance flex plate or flywheel to balance a race engine, we looked for the 6 cyl stuff new.
    SPark
  8. baddad457
    Umm, no it won't. It will be integrally cast into the flywheel. With drilled holes to fine tune the imbalance
  9. lm14
    lm14 Member
    Iowa
    I happen to have 2 old SBF aluminum flywheels that have had weights bolted to them to balance at 28oz. I don't think they are stock as it is an ugly job it. It's not the first time I've seen this done to a neutral flywheel.
    I agree it isn't common but they are still out there. I think these were Ansen and I know they haven't been used since the mid 70's.
    They also have 5 stand triple discs on them and are for sale last I knew. Belong to a friend.
    EDIT:
    You got me questioning myself so I went and looked at the one for my Maverick. It is a Ford Motorsports 164 tooth steel flywheel and is SFI certified. It's weight bolts on.
    SPark
  10. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    You're talking aftermarket flywheels and baddad is referring to OEM and that makes both of you correct.
  11. RMiller
    Kennewick, WA
    Posted too soon, since were on the subject of imbalance has anyone used one of the bolt on balance plates? Summit sells them for about $30 and they sandwich between the crank and flywheel to allow the use of neutral balance flywheels.
  12. lm14
    lm14 Member
    Iowa
  13. RMiller
    Kennewick, WA
  14. Krazy Comet
    I can't see it working on a automatic, most of the Fords I've seen the flex plate bolt heads often touch leaving the bolt pattern on the converter...
    I had to send back the first converter I bought for my Comet, it set 3/16" farther out than stock causing the flexplate to bind on the back plate...
  15. lm14
    lm14 Member
    Iowa
    On a Chevy they always go between the crank and flywheel. I think they are probably OK for normal street driving.....but who does that?!?!?
    SPark
