Best c4 gear ratio combo
Discussion in 'Parts Interchange' started by dynastymav, Jan 21, 2014.
  1. dynastymav
    dynastymav Member
    tennessee
    69 1/2 and76 maverick 76 stallion
    I was woundering what your guys opinion on the best gear ratio to run in my diff? I got a c4 trans, ford 8, 15 in wheels. Im wanting to still be able to run the interstat,but wanting to go with lower gears currently my ratio is 3.00.
  2. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    whats your tire size? and wat s the max interstate speed over your way?
  3. Bryant
    i usually recommend 3.25s.
    while tire height does have an effect on things the options on available rations really cancel out the tire height variances.
    the 3.25s will allow you keep up with traffic on the freeway but still have some more get up and go from the stop light.
  4. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    true, forgot 8in had a huge gap,,, as 3.55 is being the next
    I probably wouldnt even run that even with a 28in tire...unless I did overdrive swap
    The way I typically decide on my cars r/p ratio is based on my driving habit..usually 70-75MPH and wanting to be around 3k at those mph
  5. 71gold
    depends on how much interstate driving you do...:yup:
  6. dynastymav
    dynastymav Member
    tennessee
    Im not doing alot of interstate driving, but i would like to be able too if need be. The max speed you will see around me is seventy but to stay with traffic we are talking seventy five eighty. Far as tire size i don't know that yet Im putting this car back together. Whats the max you think 3.25 would top out at? and What Rs you think i be turning at seventy with the 3.25?
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
  8. dynastymav
    dynastymav Member
    tennessee
    Thank you 1970.:)
  9. Krazy Comet
    That figure will be true for a stick shift setup but for the average stock torque converter, I believe you need to add approx 200 RPM to the calculated RPM...
  10. dynastymav
    dynastymav Member
    tennessee
    Im running a 2500 stall
