best method for reinstalling front shocks?
Discussion in 'Technical' started by maverick7072, Nov 2, 2016.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    removed my old shocks and was wondering what is the easy method to getting the lower bolts lined up on the spring perch ,having trouble getting the out stud to fit thru the hole in the perch enough so i can get the nut started
  2. Krazy Comet
    If you have it raised by chassis, jack it up under control arm, you may need to install opposite side wheel if removed...
  3. rthomas771
    1/4" drive ratchet w/extension and 9/16" socket
  4. 71gold
    I raise car on my lift and then :jack:it up under control arm...:bouncy:
    jasonwthompson likes this.
