Best Place To Buy New Steering Gear
Discussion in 'General Maverick/Comet' started by 71maverick361, Jul 26, 2016.
  1. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
  2. Krazy Comet
    Factory manual boxes are 20:1(actually I believe 21:1), only thing I've seen with 16:1 and manual were Shelbys...
  3. tody
    tody Member
    cologne, germany
    i have rebuilt my box myself, with NOS parts, though.
    the two ratios are for manual and power steering, manual is quicker.
    the k-code mustangs (and the shelbys?) used the power steering box with manual linkage, which i did, too.
  4. Craig Selvey
    Rode's Restorations in Galion, Ohio can rebuild yours.
    NCFatBoy likes this.
  5. Krazy Comet
    Nope the P/S is quicker and requires additional effort...
    Crazy Larry likes this.
  6. 71maverick361
    Odem
    71 Grabber
    I have mine
    I will check them out
    Thanks
  7. tody
    tody Member
    cologne, germany
    you're right, i always get that wrong. same with rearend gearing. language barrier is kicking in ;)
  8. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I believe it is the same on the Mavericks/Comets as it was on the Mustangs. The P/S was quick ratio compared to M/S. As it was not true P/S but power assisted, the gear boxes were interchangeable. I recall removing P/S in a 68 Mustang. We just removed the pump, brackets and replaced the drag link with a M/S one. The steering was not pleasant IMO, but you could use headers without problems. So if you want quick ratio M/S, use the gear box from a P/S car.
  9. Krazy Comet
    Steering boxes for Mustang/Cougar are different from Maverick/Comet, these cars use same box as Torino, Fairlane and other intermediates from '67-'71...
    They can be made to fit but one bolt hole won't line up unless there are some modifications made for mounting..
  10. 71maverick361
    Odem
    71 Grabber
    Ok great info going to buy a reman one from some where
  11. krelboyne
    krelboyne Remember
    Salem, Oregon
    I will second Roger Rode of Rode's Restorations. Good guy, and he does quality work. (419) 468-5182
    When you contact Roger, say that you have the second core steering box. He might knock down the price a little. Make sure that you remove your Pitman Arm and hardware, prior to sending your core to whom ever though.
    Craig Selvey likes this.
  12. 71maverick361
    Odem
    71 Grabber
    The second core steering box??
  13. JoeB
    JoeB Member
    Stowe, PA
    71 Maverick, 72 Comet GT
  14. 71maverick361
    Odem
    71 Grabber
    Sent to Rodes Resto
