best place to put line lock??
Discussion in 'Technical' started by GTwannabe, Jun 12, 2008.
  1. GTwannabe
    GTwannabe Member
    Acworth/Kennesaw, GA
    94 mustang GT, '73 Comet GT 302 toploader 4-speed
    got a hurst line lock, just not sure where to put it. i guessing between the master and equalizer block. can anyone give me a pic of theres to help me out.
  2. scooper77515
    Here's mine...I know, ugly, but I had to bend it all by hand...
    Picture below is the wife trying it out :p
  3. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    same but different..
  4. rthomas771
    Form instructions
  5. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Scooper, never saw anyone mount above the master cylinder,,, any strange effects or after sitting for a bit do you have to pump pedal up??
    Also on mounting line lock, keep lines an wiring away from heat!
  6. comet666
    comet666 RAISE HELL AND DRINK WINE
    Sweden/Gothenburg
    Comet -74 Inline Six 250, 4.1 AT
    Stupid me, but what is it for...? :hmmm:
  7. scooper77515
    It isn't mounted as high as it looks. It is pretty much even with it, and it must be an optical illusion or camera angle making it look higher. No problems, ever, with it.
    comet666, you stomp the brakes, then hit a button inside the car, and let off the brakes. The line lock holds the brake fluid on the front brakes, but the rear tires are no longer braked and can roll freely. So while you hold the button, front tires locked with brakes on, stomp the gas and the rear tires light right up. Used for heating the tires at the track or just for a smoke show on the street.
    Otherwise, you have to hold the brake and force the rear tires to turn against the brakes, which isn't too good for the brake shoes, drums, etc.
  8. PaulS
    You should always mount the line lock after the flow control valve.
    You can make bleeding the system a lot easier if there is a bleed point above the master cylinder.
  9. GTwannabe
    GTwannabe Member
    perfect pics guys(y) thanks for the help exactly what i needed.
