big 3 upgrade
Discussion in 'Audio' started by nysean91, Sep 7, 2013.
  1. nysean91
    nysean91 Member
    1972 ford maverick
    Ok so im tryong to do the big upgrade. My question is the wire thts suppose to go from alternator to batrery, the positive wire. The positive wire on the alterbator goes to the solinoud. Ib the big 3 its suppose to run from alternator to battery. Am I doing sonething wrong or do I leave that wire or wat
  2. rthomas771
  3. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    :hmmm:........ :hmmm:......... :hmmm:
  4. nysean91
    nysean91 Member
    1972 ford maverick
    Big 3 upgrade. Wiring. Electrical.... no......
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Spell check is your friend.
  6. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
  7. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Big 3 upgrade....Its a term used for car audio and it means upgrading the factory wiring to something larger 4ga+. Upgrade positive wire from alternator to battery, upgrade battery to chassis ground and upgrade chassis to engine ground. It is supposed to help remove electrical bottlenecks.
    Sean, to answer your question it should be fine either way. On my truck I ran wire directly from alt to battery and from battery to solenoid which I believe to be more efficient.
  8. Krazy Comet
    I thought maybe it was a referral to the 3G alt upgrade, apparently like the others I didn't have a clue...
  9. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    It's understandable, the term is not really used outside the car audio world.
  10. Dave B
    I thought the big three was, Ford, GM, and Chrysler...
  11. nysean91
    nysean91 Member
    1972 ford maverick
    Thanks a lot...I jus wanted to make sure it was on with these old vehicles...im glad atleast someone knew what I was talking about..
