Black vs Stainless Steel ARP engine bolts
Discussion in 'Technical' started by mercgt73, Jun 14, 2015.
  1. mercgt73
    mercgt73 Member
    I prefer the look of ARP black bolts, but do they stay nice and black over time? If not, does anyone have problems with the stainless hardware interacting because of the dissimilar metal properties?
  2. tody
    tody Member
    cologne, germany
    i have had the black bolts in my mustang for a couple of years now. still black, no issues.
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    Probably mostly depends on your climate and what weather and storage environments.. but I can tell you with little doubt that the black coated stuff lasts nowhere as long as the stainless hardware will. It WILL eventually corrode.
    Whenever I want black hardware on my stuff to hold back on the bling or go for that stealth look.. i just hand sand, acid etch, or preferably sand blast to prep for paint. More work and pricier but best of both worlds.
  4. FomocoBoy
    FomocoBoy Member
    Western Canada
    1969.5 Maverick
  5. dyent
    dyent Member
    vancouver bc
    FYI, ARP stainless "300" are not your average stainless steel, they are stronger than grade 8.
    regarding their 8740 Chrome Moly head bolts, I have used them on my engines for over 25 years, I am
    in the Pacific Northwest where the climate is damp and right by salt water, over time they will develop a small amount of rust, mostly if the coating is scratched, but that was on my daily driver, if you only drive during sunny days, I would say black coating will last decades.......also, depends on how many times you are removing the bolts. The more often you are removing them, the more chance the coating can be scratched which will then corrode (rust).
    I have their stainless steel 12 point heads on pretty well everything else, nice and polished and never have to worry about rusting in my lifetime, stronger than grade 8. Never had any issues with them interacting with aluminum water pump or cast iron engine parts or body panels. Check out their website www.arp-bolts.com
    David
    you can also request for their free catalog, view their video's etc........
  6. Bryant
    arp doesnt do stainless head bolts last time i checked. im sure the above chart is exactly why. all the bolts for engine covers and manifold dont get torqued to their max clamping force and are fine to be stainless steel. i like using the the stainless steel ones just because of the look of them. my only concern is them going into aluminum. i have never had them size or gall on any of my motors but i did have one customers lt1 camaro have a header bolt gall and break off in the head.
    i have also seen the black bolts get some rust color to them after a while. usually on the contact edges from the tools that tightened them and compromised the coating.
  7. dyent
    dyent Member
    vancouver bc
    ARP does manufacture Stainless Steel Head Bolts for our 289/302/351 engines. Again, ARP stainless "300" is not your regular everyday stainless, check out their site and find out for yourself......
    454-3601 stainless steel hex head for 289-302 w/factory heads or Edelbrock 60259/379
    454-3701 stainless steel 12 point heads
    I've used their stainless steel header bolts on my AR-1 aluminum heads along with ultra torque fastener lube and never had any issues.
  8. mercgt73
    mercgt73 Member
    Great responses, guys! Thanks for the feedback.
    Good point with the climate. 30 miles to my west is the brackish Chesapeake Bay. 60 miles to my east is the Atlantic ocean.
    Great info! Good to hear the stainless steel hardware plays nice with the aluminum parts.
    Good info, Bryant. Thanks!
    So, because I do not want any black bolts eventually rusting, and because I live near the ocean, I'm thinking of going with ARP stainless. Sounds like as long as I use the recommended installation lubricate, the SS hardware will work just fine. Guess I gotta shell out the extra dough for the SS stuff, lol!
  9. dyent
    dyent Member
    vancouver bc
    Hi Rusty:
    I think you would be quite happy with ARP's SS bolts! Go to their site and request a free catalog or you can download a copy, lots of great info, charts etc...
    I used their 554-9501 SS 12 point head engine dress up kit, 9601 if you want hex head, also have for 351W too.
    Can find kits online for around $200, got mine for around $150, had spare set until recently sold......probably a little pricey for average person, but consider these are probably the best Automotive Fasteners that you can buy, well worth it in my opinion. Made in USA.
    Cheers,
    David
    thanks again for those MOOG upper ball joints!
  10. mercgt73
    mercgt73 Member
    Already requested a catalog! And you're welcome!
  11. baddad457
    Stainless into aluminum ? Always use antiseize on the threads (and shanks) . Matter of fact, always use it regardless of the bolt material into aluminum.
  12. mercgt73
    mercgt73 Member
    Yeah, that was my main concern with the SS hardware. ARP's installation lube seems to mitigate the dissimilar metal interactions.
