Blowing oil into the air filter
Discussion in 'General Maverick/Comet' started by Nightshade, Jun 26, 2007.
  1. Nightshade
    Nightshade Member
    Oregon
    1974 Comet
    I own a 74 Comet / slant 6. It seems like there is a lot of pressure in the engine - blowing oil out through the dipstick and blowing oil into the air filter as well.
    Any thoughts or ideas why it's doing that?
    Mark
  2. Slantsickness
    Slantsickness Member
    Tucson, Az
    1975 2 Dr.
    When an engine gets alot of miles on it, combustion pressure starts leaking past the rings into the crankcase. Its called blowby, and thats most likely whats causing the symptom you describe. A bad PCV valve could cause some blowby to be apperent, but usualy not as much as you describe. You can either
    A- rebuild or replace the engine
    or
    B-live with it as is
    Oh, BTW, these ford motors are just straight sixes. The slant six is a Mopar motor. Now i'm a Mopar guy at heart (Shh... don't tell anyone) but most ford guys (and most mopar guys too, for that matter) get a little testy when you confuse the two. As you have guessed, this board is pretty much filled with ford guys.
  3. Jamie Miles
    Your PCV valve is either removed or not functioning correctly. My 250 has 247,000 miles on it and dose not have that problem as long as the PCV valve is connected.
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Do a wet and dry compression test on the engine.....that will definately tell you the condition
  5. PaulS
    Replace the PCV valve and hose, run a leak-down test or a wet/dry compression test. If the compression is good and the cylinders seal withing 10% (high to low) then you know what the shape of the top end is. If the oil pressure is good too then the engine's condition will tell you how far away the next rebuild is. Use that information to plan the next step.
  6. Rando76
    Rando76 Member
    Claremore, OK
    Trust Paul's opinion. (y)
    I had the same problem on a 300 in a Ford truck and it was caused by blow-by. It was just worn out. I rebuilt it - no probs since.
  7. blugene
    Another possibility is the vacuum circuit to the PCV valve, it could be clogged.
  8. 74merc
    74merc computer nerd
    1974 Comet
    PCV is a cheap test and usually shows some improvement even if the rings are worn.
    Likely with the age, it needs to be rebuilt. Keep oil in it and as long as it doesn't foul the plugs, you can keep going. The less you push the engine, the less it blows oil. Mine will blow the dipstick out of the tube at wide open throttle.
  9. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Of course, the condition of your engine in no way reflects the condition of his...
  10. Nightshade
    Nightshade Member
    Oregon
    1974 Comet
    PCV Valve replaced
    Thanks for all the ideas. I was told the compression test was 120 on all 6 cylinders when I bought the vehicle. But then again, who knows if that was true. I replaced the PCV valve yesterday and plugged up any open vaccum leaks as well. The car is completely out of tune... so maybe I should just have the shop do a new compression test as well. I bought a triple gauge kit... but am figuring out how to install it now. It's not the electric one... but a mechanical one so figuring out where to put it in the engine and radiator is quite interesting.
  11. 74merc
    1974 Comet
    Might be a timing issue too. Higher timing will make an engine blow oil worse if the problem already exists.
    My 200 had 120psi across all six, didn't blow oil too bad, but leaked between the head and the block. My dad argued with me that it couldn't. After I pressure washed the engine and ran it a bit, I proved my point. Not a drop anywhere else, just leaking oil out of the headgasket.
    I don't know the sixes well enough to tell you where to put the temp sensor, someone here can definately help. I was still green when I was running the six, I assisted in most work back then rather than tackle it myself.
  12. Jamie Miles
    Mine has been relatively well taken care of (besides the part where it sat in a wheat field for 13 years with three seized valves), however, with that kind of mileage, I don't think the rings could get much worse. There is so much blow by, that it blows out around the oil fill cap and dipstick... it's losing about 2 1/2 quarts of oil between oil changes now. There still is no visible smoke coming out of the exaust though. I'm afraid to check the compression or leak down. :rolleyes:
