blown head gasket, how to flush????
Discussion in 'General Maverick/Comet' started by 71351wmav, Feb 22, 2005.
  1. 71351wmav
    71351wmav Member
    Hermiston, Oregon
    1971 maverick
    what is the best way to flush out a motor that had a blown head gasket? by the way ROL gaskets are CRAP!!!!!! i blew a head gasket during break-in, and everything is new and rebuilt and was torqued to specs. i have the heads pulled now with the motor still in the mav, is there anything i should do before re-assembly?
  2. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Need more info then that!
  3. 71351wmav
    71351wmav Member
    Hermiston, Oregon
    1971 maverick
    my head gasket blew, i have a nasty sludge in the engine now from the water and oil mixing, how do i flush it out? i used ROL gaskets and the quality of them compared to fel pro.
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Having blown a few myself, I'd say just get as much water out of the cylinder(s) as you can, change the oil and filter, coolant (if needed), and consider going to NEW ARP head bolts (with the threads dipped in motor oil before torquing). Torque in correct sequence. After 100 or so miles, re-torque the head bolts (and intake manifold and exhaust bolts), and change the oil and filter again.
    a link for some good general information:
    http://www.aa1car.com/library/ic697.htm
    good luck
  5. 460Comet
    460Comet 466 gallons/mile
    Medicine Hat AB. Canada
    1977 2 dr. 466 BBFord, C6 auto, 8 inch rear.
    More than likely, you just got a bad gasket or the surface of the head/block arent true. (Even machinists can mess up) I've used ROL gaskets ever since I had 2 FEL pro head gaskets blow out within one minute of firing a fresh 357W with brand new and very straight dart heads. I've never had a problem. Probably something simple. Hope everything works out for you!
  6. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    We always used kerosene to flush out the oil ports and stuff just put it in a garden sprayer and spray away.
