Blown Heater Core
Discussion in 'Technical' started by Jmdelto, Feb 6, 2020.
  1. Jmdelto
    Jmdelto Member
    Memphis, TN
    1972 Ford Maverick Grabber
    Greetings All!
    I believe I have a blown heater core, read through a number of posts involving coolant leaking and being noticed in the passenger side floor (bleeding coolant). What are my options, bypass for now, replace heater core, burp the system, possible clogged heater core? Ultimately I don’t want to jeopardize my engines health, I’ll post a couple of pictures (didn’t get any pics of the coolant puddled) just wanted some advice from the group. All angles appreciated.
    Thanks!
    Jim
  2. 71gold
    :Welcome:...:Handshake:
    is it antifreeze or water?
    if water, could be leaking cowl. antifreeze, heater core. you can loop the heater hose for a temp. fix.
  3. Jmdelto
    Jmdelto Member
    Memphis, TN
    It is antifreeze. What should I start with for trouble shooting? Would it leak it’s the core was clogged or do they typically leak if the core is blown?
  4. Krazy Comet
    Leak is almost always due to corrosion or maybe a cracked solder joint. Rare instances someone poked a hole in it installing a tape deck or similar.
    If it's plugged, heat will be weak at best. Replace core and don't look back.
    stumanchu, Jmdelto and BBMS18 like this.
  5. Jmdelto
    Jmdelto Member
    Memphis, TN
    Will do, thanks for the help!
  6. 71gold
    have the new heater core pressure checked before installing...:yup:
    maverick600 likes this.
  7. stumanchu
    stumanchu Stuart
    Portland, OR
    My heater box looked like this inside. Cleaning all the rusty dust and crud out, a little painting, and a new heater core almost brings back the new car smell.....well, maybe not.....but it did get rid of a little old car smell.
    maverick600 and BBMS18 like this.
